cpu Intel(R) Management Engine Interface_2316.5.0.0_10.0_x64
  • contra
  • contra's Avatar Topic Author
#1493
heci.inf
DriverVer = 04/18/2023,2316.5.0.0
mega.nz/file/mI4x2AbA#ZZAz_IkSIzl-xeqAVh...JGWi8y1-eKRIkS8HyF5E
Last edit: 1 year 7 months ago by admin.
The following user(s) said Thank You: admin, Tom
Re: Intel(R) Management Engine Interface_2316.5.0.0_10.0_x64
#1529
Intel Management Engine Interface (MEI/AMT) Version 232x.x.3x.0 WHQL
Firmware ME: 1.5MB & 5Mo
Pour Firmware Serie: 11.x, 12.x, 14.x, 15.x, and 16.x Only
Pack Version: 232x.4.3x.0 ?
Firmware Version:
Date & Version du drivers:
MEI :  04/18/2023,2316.5.0.0 New
MEI Ext: SOL : 04/18/2023,2316.5.0.0 New
SOL LMS Ext: 04/18/2023,2316.5.0.0 New
WIMAN: 07/05/2023,2327.80.70.0 New
WIMAN Ext: 07/05/2023,2327.80.70.0 New
LMS: 06/25/2023,2316.5.1.2 New
ICLS: 06/05/2023,1.67.548.0 New
DAL:  07/11/2023,1.44.2023.0710 New
MEWMIP: 04/18/2023,2316.5.0.0
MSS Ext (HSA): no
MSS (HSA) : no
WHQL: oui
Officiel: non
Download Intel Management Engine Interface (MEI/AMT) Version 232x.x.3x.0 WHQL (station-drivers.com)
The following user(s) said Thank You: Galixte, duttyend
  • Galixte
  • Galixte's Avatar
  • regular poster
  • regular poster
#1530
Thanks.
Just a comment, In your screenshot the Intel(R) Management Engine WMI Provider 2318.4.3.0 doesn’t come from the Intel Management Engine Interface (MEIAMT) Version 232x.x.3x.0 WHQL drivers package which contains MEWMIP: 04/18/2023,2316.5.0.0.
The last release of this driver comes from the Intel Management Engine Interface (MEI/AMT) Version 2321.4.31.0 WHQL drivers package.
Last edit: 1 year 7 months ago by Galixte.
  • SM-003
  • SM-003's Avatar
  • Moderator Global
  • Moderator Global
#1531
Thanks.
Just checked & that's correct.  The provided WMI SW component is v2316.5.0.0, not v2318.4.3.0.
The posted screenshot has the wrong version mentioned, but below, in the post (text) itself, the actual version is mentioned.
System H/W Specifications
Last edit: 1 year 7 months ago by SM-003.
1 year 7 months ago
#1532
Hi everyone, yes it was just a capture of the updated drivers thank you I'll be careful next time
