cpu Intel Management Engine Interface (MEI/AMT) Version 2306.4.10.0 WHQL
#991
Firmware ME: 1.5MB & 5Mo
Pour Firmware Serie: 11.x, 12.x, 14.x, 15.x, and 16.x Only
Pack Version: 2306.4.10.0 (06/02/23)
Firmware Version: 16.10.5.1583
www.station-drivers.com/index.php/en-us/...0.0-WHQL/lang,en-us/
Last edit: 1 year 10 months ago by admin.
  • moderate
  • moderate's Avatar
Re: Intel Management Engine Interface (MEI/AMT) Version 2306.4.10.0 WHQL
#993
  • Tom's Avatar
#995
You may have to explain what exactly you do.
While your first link doesn't work, but the question is from where did you get the link.
I opened the one from the mainpage and it was leading to this topic.:
www.station-drivers.com/index.php/en-us/...2306-4-10-0-whql#991
Your second link works and I am downloading it.
You have a software/antivrus installed which blocks links?
Do you have an add-on in your browser installed, which causes this problem?
Which browser do you use?
FYI, the links worked for me in Edge, FF and Chrome.
Edit: Your first link misses the "middle part" of the link: (Drivers/Intel/Management-Engine-Interface-(MEI)/Drivers/16.x/)
Last edit: 1 year 10 months ago by Tom.
  • moderate
  • moderate's Avatar
#1012
It again works now, because I reported it.
  • SM-003
  • SM-003's Avatar
  • Moderator Global
  • Moderator Global
#1016
@tom
He was right about the link.
Initially, the link was posted incorrectly, later on, it was corrected.
System H/W Specifications
Last edit: 1 year 10 months ago by SM-003.
