ssd Help needed for Realtek RTL9210B NVMe/USB 3.1 Controller firmware Version 1.33.5
  • leon22heart
  • leon22heart's Avatar Topic Author
1 month 1 week ago - 1 month 1 week ago
#4395
Hello to all. I have a Realtek usbc nvme case adapter (with fan) that came with the firmware version 1.33.5 with date 2023.10.06 . I saw that this firmware is not shared by anyone in the forum so i wanted to ask if it is possible to dump the firmware in a non destructive way ( desoldering the chip ) . Below i include some photos .
Last edit: 1 month 1 week ago by leon22heart.
Re: Help needed for Realtek RTL9210B NVMe/USB 3.1 Controller firmware Version 1.33.5
#4398
There is no tools to dump Realtek firmware
I dumped a RTL9201R a while back by removing the chip
the only way to flash it back on is via a programmer
there doesnt seem to be a simple way to make a firmware thats flashable
with Realtek's flasher
tbh there's no real point dumping it we have plenty of firmware's for the RTL9210B
with 1.33.98 being the latest
just dump the device info (nvram) with the flasher
and clone them settings before flashing the latest firmware
Last edit: 1 month 1 week ago by Shonk.
The following user(s) said Thank You: duttyend, leon22heart
  • leon22heart
#4399
Thank you for the info . It was probably your post i saw that made me question the viability of dumping this firmware without manual intervention. So i guess there is no need for such firmware .One question though , is there a guide pointing to flashing realtek firmware ? Jmicron and vli were the only ones i have tried in the past and in hdd cases that were missing the fan . My main fear is that fan will stop working.
PS Is this guide a valid one github
  • leon22heart
1 month 1 week ago
#4406
Flashed the latest firmware , everything works well . I include the config file for anyone wanting a reference.
VID = 0xbda PID = 0x9210 MANUFACTURE = "Realtek" PRODUCT = "USB3.1  USB Device" SERIAL = "012345678904" SCSI_PRODUCT = "RTL9210B-CG" SCSI_VENDOR = "Realtek" USB_SELF_PWR = 0x0 DISK_HOTPLUG = 0x0 LED = 0x2 PINMUX1 = 0x0 PINMUX2 = 0x0 U2_MAXPWR = 0x0 U3_MAXPWR = 0x0 ASPMDIS = 0x0 PCIE_REFCLK = 0x0 DISK_IPS_THRES = 0xf SWR_1_2V = 0x0 EN_UPS = 0x0 PD = 0x0 CUSTOMIZED_LED = false SUSPEND_LED_OFF = 0x3 FORCE_USB_SPEED = 0x0 FORCE_PCIE_SPEED = 0x0 EN_U1U2 = 0x0 FORCE_USB_QUIRK = 0x0 FORCE_PCIE_QUIRK = 0x0 FAN = 0x0 DIS_SHOW_EMPTY_DISK = 0x1 FORCE_SATA_NORMAL_DMA = 0x0 UART_DBG_PIN = 0x5 FINGER_PRINT_EN = 0x0 RM_INTERNAL_RD = 0x0 HS_AUTO_SWITCH = 0x0 UART_BAUD_RATE = 0x0 CUSTOMIZED_DISK_IDENTIFY = 0x0 HW_LED_CFG = 0x0 CDROM_CFG = false SUPPORT_HID = 0x0 LATE_INIT_DISK = 0x0 SCSI_WP_PIN = 0x0 SD_MMC_TYPE = 0x0 FORCE_PORT_TYPE = 0x0 BCDDEVICE = 0x0 SUSPEND_DISK_OFF = 0x0 SCSI_WB_PIN = 0x0 CUSTOMIZED_FEATURE = 0x0 PERIPH_API = 0x0 RAID_CFG = 0x0
