ssd JMicron JMS567 Firmware Collection
2 months 1 week ago - 2 months 1 week ago
#4224
Make a backup of your current firmware before Flashing anything
FwUpdateTool_v1_19_13.exe
RD Version Tick
Backup Old Firmware Only Tick
Run
Multi Drive Firmware should be fine on single drive hardware it just enables the use of Port Multipliers
Single Drive Firmware can be flashed to Multi Drive Hardware but will only show one drive
If you are running a single device
I would say Run
JMS567_22.01.00.08_Passthrough_JMicron JMS567 30 Mins PM SN.bin
JMS567_20.06.00.01_Passthrough_JMicron JMS567 30 Mins PM SN
UASP Enabled
Drive ID Passthrough Enabled
USB Device ID Device Manufacturer: JMicron
USB Device ID Product Name: JMicron JMS567
Drive Sleep after 30 Mins
SMART Passthrough Enabled
Serial Number Passthrough Enabled
If you are running a 4 bay device
I would say Run
JMS567_20.06.00.01_Passthrough_JMicron JMS567 30 Mins PM.bin
UASP Enabled
Serial Number Passthrough not enabled (works on single drive but not with more than one drive)
Firmware Seems to get confused with multiple drives with it enabled so sn is blank
TRIM not enabled on any chip before JMS578
mega.nz/file/9vQDkSAJ#sr4aQvBHVTB-MEc9B4...lUK5Ka5RcglXuWY3wcZg
DLSIN DLA614SUSJ3 JMS567 + JMB575
Last edit: 2 months 1 week ago by Shonk.
  • emmausa0106
  • emmausa0106's Avatar
Re: JMicron JMS567 Firmware Collection
1 month 3 weeks ago - 1 month 3 weeks ago
#4337
It is extremely important to back up your current firmware before you perform any new firmware flashing (writing) operations.
Last edit: 1 month 3 weeks ago by emmausa0106.
Time to create page: 0.073 seconds
