ssd Jmicron JMS580 firmware avec nvram
#3843
I am looking for the latest firmware for the JMS580 with Nvram because the others do not work
Last edit: 4 months 3 weeks ago by admin.
  • Tom's Avatar
Re: Jmicron JMS580 firmware avec nvram
#3845
Did you check this topic ?
#3846
Thanks Tom but it's for the JMS580 but not the JMS583
I'm looking for my 256GB Fanxiang USB 3.2 key
#3847
Same problem with JMS581 im sure something will turn up at some point
