ssd Asmedia ASM-2364 NVMe/USB 3.2 Controller firmware Version 230927_91_00_00
  • Julia
  • Julia's Avatar
6 months 1 day ago - 6 months 1 day ago
#3642
@Shonk,
I have set everything apart from Idle Time (the setting in the ini is ignored for some reason)
Set:
[usb_config]
standby_timer=3
Last edit: 6 months 1 day ago by Julia.
#3644
the setting in the ini is ignored for some reason and it never goes to sleep
i use the pulldown to change it to 10 mins
and now power management works for me
the flash tool is slightly newer than when i tested this
so maybe its fixed in the tool i havnt checked
but i do it anyway to ensure power management works
Last edit: 6 months 1 day ago by Shonk.
6 months 20 hours ago - 6 months 20 hours ago
#3645
My antivirus blocked the MPTool and since then, despite my research, it has been impossible to remove the ban.
Last edit: 6 months 20 hours ago by admin.
#3646
Last edit: 6 months 20 hours ago by Shonk.
  • H3li03
  • H3li03's Avatar
5 months 6 days ago
#3810
Hi there, I have a sandisk extreme enclosure with the same chipset, I was hoping to be able to flash a generic firmware to be able to use any nvme drive with it, cause with it's firmware, the device only recognize sandisk drive included...
I tried opening the flasher, but it seems it can't find the device from usb list, I was able to dump the firmware with asm firmware reader, the file name is asm_fw_181206_81_E3_08.bin
any idea?
thank, and sorry if it's a dumb request.
