ssd Asmedia ASM-2364 NVMe/USB 3.2 Controller firmware Version 230927_91_00_00
  • spike_V_sky
  • spike_V_sky's Avatar
4 months 2 weeks ago
#3910
@Shonk
AS_PCIE_230927_91_00_00.bin (2 of my devices came with this firmware)
Directly Dumped from my Samget Enclosure (ASM2364)
hi, i have the same enclousere
Do you know what is fixed for this fw version ?
About the issue you had with the enclouser is specific of the PM9B1 ?
3 months 4 weeks ago
#4014
its specific to the PM9B1 and is the same with any ASM2364 firmware
  • Stasiz
  • Stasiz's Avatar
#4141
@Shonk
Thanks!
I have successfully updated ORICO-M233C3-G4 with ASM2362 to AS_PCIE_230927_91_00_00.bin
Last edit: 3 months 1 week ago by Stasiz.
  • spike_V_sky
3 months 2 days ago - 3 months 2 days ago
#4170
@Shonk
works fine here, thanks for share.
Do you know the  thickness, and thermal characteristics of the thermal pad provided in the package with the enclosure, in case I need to replace it ?
My enclouser at idle report 35°C, seem a bit hight ....
Last edit: 3 months 2 days ago by spike_V_sky.
#4171
Its just your usual generic china 5 W/mk pad at a guess 1 or 1.5mm you need as thick as it takes to close the enclosure with a slight bit of pressure but not to much
to thin and it wont transfer the heat
35°C is fine its in an enclosure not a huge pc with airflow 75°C is high
MY Axe Speedy+ 1TB usb stick is 63°C at idle that thing is hot
your cooler than all of my ssd's in my main pc which has 6 140mm case fans
and a small fan blowing over the ssd's
Intel Optane 900P 480GB 39°C M.2
Intel Optane 900P 480GB 36°C U.2
Samsung 990 Pro 4TB 42°C M.2
Samsung 990 Pro 2TB 41°C M.2
Samsung 990Pro 2TB 43°C M.2
Samsung 980Pro 2TB 43°C M.2
AXE Speedy+ 1TB 63°C USB Stick
Last edit: 3 months 2 days ago by Shonk.
