1 year 9 months ago - 11 months 6 days ago
Edit Here's The firmware we have atm
if you get anything newer plz pass it on
MPtool_Lite v2.0.4.31219 (New)
RTL9201VBL_v1.32.7.112522_signed.bin
RTL9201VB_gd_v4.32.88.082923_signed.bin (New)
mega.nz/file/prpSgSAa#FyZ24FfE7p-tkArkGp...eCW2lXQLasseUGTC3onw
************************************************************** Cofre Disco Duro Enclosures The drive disapears on this firmware on the two 9.32.74 devices i have plugged in alot they just disapear at random with the RTL9201R still connected it seems to be a firmware bug have put them onto 1.32.7 The disco led doesnt work but whatever if it fixes the enclosures ************************************************************** Device : [Port18] : Realtek RTL9201 #0 ************************************************************** U2PHY : n/a U3PHY : n/a VID : 0x0bda PID : 0x9201 MANUFACTURE : "Realtek" PRODUCT : "RTL9201" SERIAL : "012345678942" SCSI_PRODUCT : "RTL9201         " SCSI_VENDOR : "Realtek " USB_SELF_PWR : n/a DISK_HOTPLUG : n/a LED : 0x01 PINMUX1 : n/a PINMUX2 : n/a U2_MAXPWR : n/a U3_MAXPWR : n/a ASPMDIS : n/a PCIE_REFCLK : n/a DISK_IPS_THRES : n/a SWR_1_2V : n/a EN_UPS : n/a PD : n/a CUSTOMIZED_LED : 41 00 00 00 00 00 00 00 00 00 00 00 00 00 00 SUSPEND_LED_OFF : n/a FORCE_USB_SPEED : n/a FORCE_PCIE_SPEED : n/a EN_U1U2 : n/a FORCE_USB_QUIRK : n/a FORCE_PCIE_QUIRK : n/a FAN : n/a DIS_SHOW_EMPTY_DISK : n/a FORCE_SATA_NORMAL_DMA : n/a UART_DBG_PIN : 0x64 FINGER_PRINT_EN : n/a RM_INTERNAL_RD : n/a HS_AUTO_SWITCH : n/a UART_BAUD_RATE : n/a CUSTOMIZED_DISK_IDENTIFY : n/a HW_LED_CFG : n/a CDROM_CFG : n/a SUPPORT_HID : n/a LATE_INIT_DISK : n/a SCSI_WP_PIN : n/a SD_MMC_TYPE : n/a FORCE_PORT_TYPE : n/a BCDDEVICE : n/a SUSPEND_DISK_OFF : n/a SCSI_WB_PIN : n/a CUSTOMIZED_FEATURE : n/a PERIPH_API : n/a RAID_CFG : n/a Boot Mode : Flash FW Ver : 9.32.74 FW Build Date : 2023.07.17 IC Pkg Type : SATA UUID : n/a Disconn_ForceUSB2 : false ************************************************************** UTHAI Q5 + Q6 + Q7 Enclosures ************************************************************** Device : [Port19] : Crucial_ CT512M550SSD1 #1 ************************************************************** U2PHY : n/a U3PHY : n/a VID : 0x0bda PID : 0x9201 MANUFACTURE : "Realtek" PRODUCT : "RTL9201" SERIAL : "012345678999" SCSI_PRODUCT : "n/a" SCSI_VENDOR : "n/a" USB_SELF_PWR : n/a DISK_HOTPLUG : 0x03 LED : 0x03 PINMUX1 : n/a PINMUX2 : n/a U2_MAXPWR : n/a U3_MAXPWR : n/a ASPMDIS : n/a PCIE_REFCLK : n/a DISK_IPS_THRES : 0x03 SWR_1_2V : n/a EN_UPS : n/a PD : n/a CUSTOMIZED_LED : 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 SUSPEND_LED_OFF : n/a FORCE_USB_SPEED : n/a FORCE_PCIE_SPEED : n/a EN_U1U2 : n/a FORCE_USB_QUIRK : n/a FORCE_PCIE_QUIRK : n/a FAN : n/a DIS_SHOW_EMPTY_DISK : 0x01 FORCE_SATA_NORMAL_DMA : n/a UART_DBG_PIN : 0x64 FINGER_PRINT_EN : n/a RM_INTERNAL_RD : n/a HS_AUTO_SWITCH : n/a UART_BAUD_RATE : n/a CUSTOMIZED_DISK_IDENTIFY : n/a HW_LED_CFG : n/a CDROM_CFG : n/a SUPPORT_HID : n/a LATE_INIT_DISK : n/a SCSI_WP_PIN : n/a SD_MMC_TYPE : n/a FORCE_PORT_TYPE : n/a BCDDEVICE : n/a SUSPEND_DISK_OFF : n/a SCSI_WB_PIN : n/a CUSTOMIZED_FEATURE : n/a PERIPH_API : n/a RAID_CFG : n/a Boot Mode : Flash FW Ver : 1.32.7 FW Build Date : 2022.11.25 IC Pkg Type : SATA UUID : n/a Disconn_ForceUSB2 : false
Last edit: 11 months 6 days ago by Shonk.
  • AOnurY
  • AOnurY's Avatar
  • User
  • User
Re: RTL9201 Firmware?
1 year 6 months ago
  • Pablo_24
  • Pablo_24's Avatar
1 year 6 months ago
Hi,  Shonk , i try this firmware and works correct with my RTL9201R-VB-CG.
RTL9201(R)v1.32.7z
PID : 0x9201
PRODUCT : "RTL9201"
DISK_HOTPLUG : n/a
PINMUX1 : n/a
PINMUX2 : n/a
U2_MAXPWR : n/a
U3_MAXPWR : n/a
ASPMDIS : n/a
UART_DBG_PIN : 0x64
FW Ver : 9.32.74
IC Pkg Type : SATA
  • mizoarc
  • mizoarc's Avatar
1 year 6 months ago
thank you
1 year 6 months ago
thanks where did you find it
