Re: Realtek RTL9201 Firmware 1.32.7 / 9.32.74 / 1.33.3 / 1.33.88 / 9.34.11 / 1.34.29
2 months 6 days ago - 2 months 6 days ago
I have been trying on and off to extract firmware from a Realtek SPI dump for about a year.
I was able to extract v1.32.7 a while ago, but firmware versions newer than v1.32.7 are structured differently and are even flashed differently by MPtool Lite.
The key was using the v9.34.11 firmware to compare how it was structured.
Anyway, one thing I have noticed since I added a 4Mbit SPI to the UTHAI Q5/Q6/Q7 the config for them uses these parameters:
- LED = 0x3
- CUSTOMIZED_LED = 08 00
- UART_DBG_PIN = 100
- DISK_HOTPLUG = 0x3
- DISK_IPS_THRES = 0xa
- DIS_SHOW_EMPTY_DISK = 0x1
DISK_HOTPLUG is not supported on newer firmwares and causes disconnection/firmware crash issues after the drive goes to sleep. DISK_IPS_THRES seems fine.
hence why enclosures coming with newer firmware dont have it in the config or have commented it out with updates like is the case with jeyi
Compatibility Results for DISK_HOTPLUG = 0x3
- RTL9201VB_v1.32.7.112522_signed.bin = Fine
- RTL9201VB_v9.32.74_071723_dbg.bin = Untested
- RTL9201VB_v1.33.3.092723_signed.bin = Untested
- RTL9201VB_v1.33.88.071824_signed.bin = Untested
- RTL9201VB_v9.34.11.102524_dbg.bin = Not Working
- RTL9201VB_v1.34.29.011325_signed.bin = Not Working
- LED = 0x3
Last edit: 2 months 6 days ago by Shonk.
1 month 3 weeks ago - 4 weeks 6 hours ago
I had 3 Ugreen US221 Enclosures arrive today i have 5 already they are all ASMedia ASM235CM 10Gbps Sata Enclosures
anyway the three that arrived today one was ASMedia ASM235CM the other two where RTL9201-VB-CG and are 10Gbps
so the RTL9201R is the downbin locked at 5Gbps I updated them to 1.34.29 fine from 1.33.3 that Ugreen had used
All the latest firmware's i have for all of my devices are here
github.com/Shonk/RTL92XX
here's the cfg for the Ugreen US221 RTL9201 Variant
Here's them updated to 1.34.29
Device : [Port4] : Crucial_ CT512M550SSD1 #0
PID : 0x9201
MANUFACTURE : "Ugreen"
PRODUCT : "Ugreen Storage Device"
SERIAL : "1333092759D7"
SCSI_PRODUCT : "n/a"
SCSI_VENDOR : "n/a"
DISK_HOTPLUG : 0x03
PINMUX1 : n/a
PINMUX2 : n/a
U2_MAXPWR : n/a
U3_MAXPWR : n/a
ASPMDIS : n/a
DISK_IPS_THRES : 0x03
CUSTOMIZED_LED : 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DIS_SHOW_EMPTY_DISK : 0x01
UART_DBG_PIN : 0x64
RW_MODE : n/a
FORCE_SATA_QUIRK : n/a
FW Ver : 1.33.3
FW Build Date : 2023.09.27
IC Pkg Type : SATA
Last edit: 4 weeks 6 hours ago by Shonk.
1 week 3 days ago
New Firmware 1.35.24
Station-Drivers - News
The following user(s) said Thank You: Shonk, Stasiz
1 week 3 days ago - 1 week 3 days ago
Where did you get this admin
Dont use the updater exe with RTL9210R btw it adds some weird flags to the config
one of which is force 10Gbps which is disabled on RTL9201R at the factory in the downbin process
so you only get USB 2.0 Connects after the update
using it with the Windows Gui updater and your old config is fine
With the New Command line updater
With Windows Gui Updater and correct config for my Device
C:\Realtek_RTL9201VB_1.35.24>rtk_fwupdate_signed
[INFO] Loaded config: C:\Realtek_RTL9201VB_1.35.24\config.ini
[INFO] rtk_fwupdate v1.0.0.60820 - Firmware Update Tool
[INFO] Bin: C:\Realtek_RTL9201VB_1.35.24\RTL9201VB_v1.35.24.072426.bin
[INFO] Rescue: C:\Realtek_RTL9201VB_1.35.24\RTL9201VB_gd_v4.32.88.082923_signed.bin
[INFO] Config: C:\Realtek_RTL9201VB_1.35.24\RTL9201.cfg
[INFO] LED: (none)
[INFO] Running as administrator
[INFO] Expected FW version: 1.35.24, build date: 072426
[INFO] Scanning for devices...
[INFO] Found device: \\.\PhysicalDrive1
[INFO] Current FW version: 1.34.29, build date: 011325 (yyyymmdd: 20250113)
[INFO] FW version differs: expected 1.35.24, current 1.34.29
[INFO] Proceeding with firmware update...
[INFO] Firmware update completed successfully.
[INFO] Waiting for device to reconnect...
[INFO] Device reconnected: \\.\PhysicalDrive1
[INFO] New FW version: 1.35.24, build date: 20260724
Last edit: 1 week 3 days ago by Shonk.
The following user(s) said Thank You: admin, Stasiz
1 week 1 day ago - 1 week 1 day ago
Last edit: 1 week 1 day ago by Shonk.
