Realtek RTL8812AU/8192 AU.. USB Wlan Drivers 1030.39.106.2025 (22.05.2025)
- fikotr74
3 months 2 days ago - 4 hours 10 minutes agoRealtek AC /b.g.n (2.4Ghz & 5Ghz ) USB Wlan Drivers 1030.39.106.2025 (22.05.2025)
RTL8188EU , RTL8188FU , RTL8192AU , RTL8192FU , RTL8703BU , RTL8710BU , RTL8723BU , RTL8723DU , RTL8811AU , RTL8811CU , RTL8812AU , RTL8812CU , RTL8814AU , RTL8821CU ,RTL8822BU , RTL8822CU ,
Supported devices : ASUS USB-AC56 802.11ac Wireless USB Adapter - ASUS USB-AC68 USB Wireless adapter - TP-LINK Wireless USB Adapter - D-Link DWA-131 Wireless N Nano USB Adapter - D-Link DWA-192 AC1900 Wi-Fi USB 3.0 Adapter - D-Link DWA-125 Wireless N 150 USB Adapter( rev D) - D-Link DWA-123 Wireless N 150 USB Adapter ( rev D ) - D-Link GO-USB-N150 Wireless N 150 Easy USB Adapter( rev B ) - D-Link DWA-171 Wireless AC Dual Band Adapter - D-Link DWA-171 Wireless AC Dual Band Adapter - Realtek RTL8811AU Wireless LAN 802.11ac USB 2.0 Network Adapter - Realtek RTL8188EU Wireless LAN 802.11n USB 2.0 Network Adapter - Realtek RTL8188FTV Wireless LAN 802.11n USB 2.0 Network Adapter - Realtek RTL8703B Wireless LAN 802.11ac USB 2.0 Network Adapter - Realtek RTL8723B Wireless LAN 802.11n USB 2.0 Network Adapter - Realtek RTL8188EE-VAU Wireless LAN 802.11n USB minicard - Realtek RTL8188ETV Wireless LAN 802.11n USB 2.0 Network Adapter - Realtek RTL8192EU Wireless LAN 802.11n USB 2.0 Network Adapter - Realtek 8822BU Wireless LAN 802.11ac USB NIC - Realtek 8812AU Wireless LAN 802.11ac USB NIC - RTL8812AU-VS (802.11ac 2x2 USB2.0) - RTL8812AU-VL (802.11ac 1x1 USB2.0) - RTL8812AU-VN(802.11n 2x2 USB2.0) - Realtek 8814AU Wireless LAN 802.11ac USB NIC - Belkin USB Wireless Adapter - NETGEAR A6200V2 11AC Wireless USB 3.0 Adapter - D-Link DWA-183 Wireless AC Dual Band USB Adapter - D-Link DWA-182 Wireless AC Dual Band USB Adapter ( rev B ) - Wireless AC1200 Dual Band USB Adapter - Edimax AC1200 Wireless LAN USB Adapter - Sitecom WiFi USB adapter AC1200 - I-O DATA WN-AC867U Wireless LAN Adapter - Logitec AC866 Wireless USB Adapter - Hawking USB Wireless-AC Network Adapter - NEC AtermWL900U (PA-WL900U) Wireless Network Adapter - WD My Net AC USB Adapter - EnGenius 802.11ac Dual Band Wireless USB Adapter - Linksys WUSB6300 - Amped Wireless ACA1 Wi-Fi Adapter - GW-900D' TRENDnet_805B AC1200 Dual Band Wireless USB Adapter - BUFFALO WI-U3-866D Wireless LAN Adapter - BUFFALO WI-U2-433DM Wireless LAN Adapter - Edimax AC600 Wireless LAN USB Adapter - ELECOM WDC-433DU2H 11ac Wireless Adapter - ELECOM WDC-300SU2S Wireless Adapter - ELECOM WDC-150SU2M Wireless Adapter - Hawking USB WLS 11AC Adapter - I-O DATA WN-AC433UA Wireless LAN Adapter' TRENDnet_804B AC600 Dual Band Wireless USB Adapter - I-O DATA WN-AC433UM Wireless LAN Adapter - ELECOM WDC-1300DU3 Wireless Adapter - ELECOM WDC-1300SU3 Wireless Adapter - Edimax AC1750 Wi-Fi USB Adapter' WiFi USB adapter AC1750 - ZyXEL Wireless AC USB Adapter
PCI \ VEN_10EC & DEV_8176
PCI \ VEN_10EC & DEV_8177
(NEW UPDATE)
1030.39.106.2025 (22.05.2025) DOWNLOAD (Thank you "Marek_848") MiCROSOFT CATALOG DOWNLOAD
OLD DRIVERS
1030.52.325.2025 (25.03.2025) DOWNLOAD 32 BIT - DOWNLOAD 64 BIT (OLD)
Last edit: 4 hours 10 minutes ago by fikotr74.
- Marek_848
3 weeks 4 days ago - 3 weeks 4 days ago
130.52.424.20258814AU Wireless LAN 802.11ac USB NICVersion: 1030.52.424.2025Date: 30 April 2025Size: 16 MBINF file: netrtwlanu.inf
Last edit: 3 weeks 4 days ago by Marek_848.
- fikotr74
Last edit: 3 weeks 4 days ago by fikotr74.
3 weeks 3 days ago
Gigabyte Z890 Master, Intel Cpu Core Ultra 7 265K, Memoires 32Go Corsair DDR5 (6000Mhz CL30), Water-cooling Thermaright, nVidia Geforce RTX4060, Alimentation Gigabyte 850W, Samsung SSD 990 Pro, SSD9100 Pro, Clavier Razer Black Window , Souris Razer, Boitier NZXT H6, HP Steelserie, Free Fibre Ultra (8Go/8Go), Lan 10Gb, Cable CAT8/7, Switch 10/5/2.5Gbps, Casque Philips Fedelis.
3 weeks 3 days ago
