rom Realtek RTL8812AU/8192 AU./8723DU.USBWlan Driver 1030.52.731.2025 (31.07.2025)
  • fikotr74
  • fikotr74's Avatar Topic Author
RTL8723DU/8812AU/8192 AU...Realtek USB Wlan Driver 1030.52.731.2025 (31.07.2025)
7 months 3 weeks ago - 3 months 2 weeks ago
#4606
        Note: The latest driver is in the latest message.
        Realtek  AC /b.g.n (2.4Ghz & 5Ghz ) USB Wlan Drivers 1030.39.106.2025 (22.05.2025
RTL8188EU , RTL8188FU , RTL8192AU , RTL8192FU , RTL8703BU , RTL8710BU , RTL8723BU , RTL8723DU , RTL8811AU , RTL8811CU , RTL8812AU , RTL8812CU , RTL8814AU , RTL8821CU ,RTL8822BU , RTL8822CU ,
Supported devices :  ASUS USB-AC56 802.11ac Wireless USB Adapter - ASUS USB-AC68 USB Wireless adapter - TP-LINK Wireless USB Adapter - D-Link DWA-131 Wireless N Nano USB Adapter - D-Link DWA-192 AC1900 Wi-Fi USB 3.0 Adapter - D-Link DWA-125 Wireless N 150 USB Adapter( rev D) - D-Link DWA-123 Wireless N 150 USB Adapter ( rev D ) - D-Link GO-USB-N150 Wireless N 150 Easy USB Adapter( rev B ) - D-Link DWA-171 Wireless AC Dual Band Adapter - D-Link DWA-171 Wireless AC Dual Band Adapter - Realtek RTL8811AU Wireless LAN 802.11ac USB 2.0 Network Adapter - Realtek RTL8188EU Wireless LAN 802.11n USB 2.0 Network Adapter - Realtek RTL8188FTV Wireless LAN 802.11n USB 2.0 Network Adapter - Realtek RTL8703B Wireless LAN 802.11ac USB 2.0 Network Adapter - Realtek RTL8723B Wireless LAN 802.11n USB 2.0 Network Adapter - Realtek RTL8188EE-VAU Wireless LAN 802.11n USB minicard - Realtek RTL8188ETV Wireless LAN 802.11n USB 2.0 Network Adapter - Realtek RTL8192EU Wireless LAN 802.11n USB 2.0 Network Adapter - Realtek 8822BU Wireless LAN 802.11ac USB NIC - Realtek 8812AU Wireless LAN 802.11ac USB NIC - RTL8812AU-VS (802.11ac 2x2 USB2.0) - RTL8812AU-VL (802.11ac 1x1 USB2.0) - RTL8812AU-VN(802.11n 2x2 USB2.0) - Realtek 8814AU Wireless LAN 802.11ac USB NIC -  Belkin USB Wireless Adapter - NETGEAR A6200V2 11AC Wireless USB 3.0 Adapter - D-Link DWA-183 Wireless AC Dual Band USB Adapter - D-Link DWA-182 Wireless AC Dual Band USB Adapter ( rev B ) - Wireless AC1200 Dual Band USB Adapter - Edimax AC1200 Wireless LAN USB Adapter - Sitecom WiFi USB adapter AC1200 - I-O DATA WN-AC867U Wireless LAN Adapter - Logitec AC866 Wireless USB Adapter - Hawking USB Wireless-AC Network Adapter - NEC AtermWL900U (PA-WL900U) Wireless Network Adapter - WD My Net AC USB Adapter - EnGenius 802.11ac Dual Band Wireless USB Adapter - Linksys WUSB6300 - Amped Wireless ACA1 Wi-Fi Adapter - GW-900D' TRENDnet_805B AC1200 Dual Band Wireless USB Adapter - BUFFALO WI-U3-866D Wireless LAN Adapter - BUFFALO WI-U2-433DM Wireless LAN Adapter - Edimax AC600 Wireless LAN USB Adapter - ELECOM WDC-433DU2H 11ac Wireless Adapter - ELECOM WDC-300SU2S Wireless Adapter - ELECOM WDC-150SU2M Wireless Adapter - Hawking USB WLS 11AC Adapter - I-O DATA WN-AC433UA Wireless LAN Adapter' TRENDnet_804B AC600 Dual Band Wireless USB Adapter - I-O DATA WN-AC433UM Wireless LAN Adapter - ELECOM WDC-1300DU3 Wireless Adapter - ELECOM WDC-1300SU3 Wireless Adapter - Edimax AC1750 Wi-Fi USB Adapter' WiFi USB adapter AC1750 -  ZyXEL Wireless AC USB Adapter
PCI \ VEN_10EC & DEV_8176
PCI \ VEN_10EC & DEV_8177
 PREVIOUS DRIVERS
1030.44.1014.2024 (14.10.2024) DOWNLOAD
1030.52.325.2025  (25.03.2025)   DOWNLOAD  x32 -  DOWNLOAD  x64
1030.39.106.2025  (22.05.2025)  DOWNLOAD   (Thank you Marek_848) -   MiCROSOFT CATALOG DOWNLOAD
1030.52.731.2025  (31.07.2025)   DOWNLOAD   (Thank you  Marek_848)
NOTE 1 : Friends, the hardware compatibility of the driver is in the first message of this topic.
NOTE 2 :If you experience connection and gain issues after installing the latest driver, it is recommended to revert to the previous driver.
Last edit: 3 months 2 weeks ago by fikotr74.
  • Marek_848
  • Marek_848's Avatar
  • poster 5
  • poster 5
5 months 2 weeks ago - 5 months 2 weeks ago
#4955
130.52.424.20258814AU Wireless LAN 802.11ac USB NICVersion: 1030.52.424.2025Date: 30 April 2025Size: 16 MBINF file: netrtwlanu.inf
Last edit: 5 months 2 weeks ago by Marek_848.
  • fikotr74
#4956
Last edit: 5 months 2 weeks ago by fikotr74.
#4957
Asus Z890 ProArt, Intel Cpu Core Ultra 7 265K, Memoires 32Go Corsair DDR5 (6000Mhz CL30), Water-cooling Thermaright, nVidia Geforce RTX4060,  Alimentation Gigabyte 850W, Samsung SSD 990 Pro, SSD9100 Pro, Clavier Razer Black Window , Souris Razer, Boitier HUMMER, HP Steelserie, Free Fibre Ultra (8Go/8Go), Lan 10Gb, Cable CAT8/7, Switch 10/5/2.5Gbps, Casque Philips Fedelis.
  • Tom's Avatar
#4958
