Issues with inserting pictures
[No more] Issues with inserting pictures
1 year 2 months ago - 1 year 1 month ago
I just made a reply into the
topic
When adding an image link, the text of the link didn't show up, instead the button for "Text Color" was pressed.
Posting the resulted that the picture shows up now 2 times + another text link.
When I try to edit the post, and click on Submit, nothing happens, I can only cancel it.
Second, but this is minor.
When I click on Forum from the homepage, the it opens recent topics and not the Index with an overview of the forum.
Need to click on Index again, to have the view I prefer.
Possible to change that behavior?
I use FF 122.0.1, so I don't rule out that FF is to blame.
Last edit: 1 year 1 month ago by Tom.
Re: Issues with inserting pictures
1 year 2 months ago
Hi Tom for my part no problems with Edge?
1 year 1 month agoTried with Edge, same problem, but worked in Chrome.Hi Tom for my part no problems with Edge?
Probably a mystery which never can be solved.
1 year 1 month ago
Did you clear the browser cache files?
1 year 1 month ago
Cache was cleared, but I think I know what happened.
When I posted the first image file, the link didn't show up.
So I made it a second time, link still didn't show up.
Then I used the IMG Tag and in the IMG tag was the 3rd time the link with another IMG-Tag, but again, it didn't show up.
But, the 3rd link (with the double IMG Tag [IMG]IMG] was hindden behind the second link. It was never visible, when I edited it.
When I deleted the 2nd image, the double IMG-Tag wasn't seen.
So I deleted everything what was behind the 1st image which caught also the double IMG-Tag and then it was fine.
But this was done in Chrome, so I am not sure whether the same solution would have worked also in Edge or FF.
