[Fixed] Mistakes on the mainpage
  • Tom's Avatar Topic Author
#1690
There are 21 mistakes on the mainpage.
1. The Driver version for Intel® Arc™ Graphics Windows* DCH is 31.0.101.4826 and not 31.0.101.48265.
2. The link of Intel PROSET/Wireless Bluetooth software Version 23.0.0.6 WHQL leads to ntel PROSET/Wireless Wifi software Version 23.0.0.18 WHQL
Last edit: 1 year 6 months ago by Tom.
The following user(s) said Thank You: grimson, duttyend
Re: Mistakes on the mainpage
#1691
Oups Sorry, thank you very much Tom
The following user(s) said Thank You: duttyend, pipes80@live.it
1 year 1 month ago
#2494
The driver for the AMD GPU is version 24.2.1, though the link is going to v24.1.1, but the newer driver is below that.
1 year 1 month ago
#2495
Oups Thx Tom
The following user(s) said Thank You: Tom, duttyend
1 year 1 week ago
#2629
Ok, I am now confused, whats going on with the mainpage which don't make sense to me:
  1. Realtek RTL8723DE/8822CE/8822BE/8821/... Wireless LAN Version 2024.10.228.9 WHQL and  Realtek RTL8852BE/8852AE/8852CE, ... Wireless LAN Version 6101.19.117.0 WHQL target different devices according to the header, but the description and the download is the same.
  2. March 25, 2024 the Intel WiFi and Bluetooth drivers 23.30 were posted again and marked as complete regardless that the same driver version was already posted on February 28, 2024 and marked as complete.
  3. AMD GPU drivers are complete ignored or not posted correctly. There are now separate drivers for Legacy models and RDNA models, but either one is linked only and then the header doesn't fit the link or not posted at all.
