Kowsi KWS-X1 USB-C PD QC Tester Firmware V1.0.4
1 year 4 weeks ago - 1 year 4 weeks ago
USB-C Multi-function full protocol, curve measurement, ripple measurement, E-Marker tester
Fully compatible with fast charging protocol and Qualcomm QC 3.0 / 4.0 protocol, compatible with a variety of protocols fast charging, support PD/QC2.0/3.0/4.0, MTK and other protocols. Support automatic protocol detection, PD2.0, 3.0, PPS, QC, FCP, SCP, AFC, PE, DASH VOOC, SuperVooc and so on.
Update
1. Press and hold back and OK and plug in the USB-C cable in female USB-C Port, Bootloader will appear on Display.
2. Start the program.
3. Perform Firmware update!
V1.0.1 - Standard Firmware
V1.0.2 - Performance improvements, fixes for some bugs related to Public-PD
V1.0.3 - E-Marker, keep reset when Public-PD detection on, Translation
V1.0.4 - Bugfixes ,Translation and new E-Marker Menu, Support to read E-Marker on Cable
Download !
Update
Download !
Last edit: 1 year 4 weeks ago by sdefrwggerg.
The following user(s) said Thank You: grimson, mountainmanjoe
- mountainmanjoe
Re: Kowsi KWS-X1 USB-C PD QC Tester Firmware V1.0.4
3 months 6 days ago - 3 months 6 days ago
I received my KWS-X1 from Aliexpress today (seller: ThinkingLeader, 17 CAD).
It came with firware version 1.0.5
It's a bit buggy. (resets itself often)
Last edit: 3 months 6 days ago by mountainmanjoe.
