Re: AMD Ryzen™ Master Overclocking Utility
6 months 1 week ago
Yes, and Intel does the same thing with Intel Extreme Tuning Utility
6 months 1 week ago
AMD released AMD Ryzen™ Master v3.1.0.5185 on May 11, 2026 for Ryzen 5000 and later
v2.14.3.5040, March 13, 2026, for Ryzen 3000 Series to Ryzen 4000
2.13.1.3097, May 28, 2024, for Ryzen 2000 and earlier
Ryzen 5000 Series and later:
Release Highlights:
Release Highlights:
Release Highlights:
Ryzen 5000 and later:
Release Notes: www.amd.com/en/resources/support-article...EN-MASTER-3-1-0.html
User Guide: docs.amd.com/r/en-US/68886-ryzen-master-user-guide
Download: www.amd.com/en/products/software/ryzen-master.html#download
Ryzen 3000 Series to 4000:
Release Notes: www.amd.com/en/resources/support-article...TER-2-14-3-5040.html
Ryzen 2000 and earlier:
Release Highlights:
- Added support for the Curve Shaper feature – a fine‑grain voltage/frequency tuning capability that allows selective voltage adjustments across temperature and frequency bands; applicable to the AMD Ryzen™ 9000 Series.
- N/A
- The application may take a bit longer to load on systems with higher core count CPUs
- In certain scenarios, when Ryzen Master is launched from AMD Software: Adrenalin Edition™, Ryzen Master Dashboard may not display accurate metric values. As a workaround, restart your system, and then launch Ryzen Master before starting AMD Software: Adrenalin Edition™.
Release Highlights:
- Adds support for AMD Ryzen™ 3000 series to AMD Ryzen™ 4000 series processors
- N/A
- On some CPUs, stress test (activated through the features 'Apply & Test' or 'Curve Optimizer Automatic') might not fully stress the CPU or might require additional time to apply maximum stress. In such situations, consider increasing the stress test duration from the settings page
- There may be minor discrepancies between the duration specified by the user and the actual time required for the stress test to complete
Release Highlights:
- This update resolves the issue of certain CPU parameters being shown incorrectly after upgrading the BIOS on AM5 platform systems utilizing AMD Ryzen™ 8000G Series desktop processors
The following user(s) said Thank You: mdm
4 months 2 days ago
AMD released AMD Ryzen™ Master v3.1.1.5502 on July 22, 2026 for Ryzen 5000 and later
Release Highlights:
Release Highlights:
Release Highlights:
Release Notes: www.amd.com/en/resources/support-article...EN-MASTER-3-1-1.html
Release Highlights:
- Added support for the Curve Shaper feature – a fine‑grain voltage/frequency tuning capability that allows selective voltage adjustments across temperature and frequency bands; applicable to the AMD Ryzen™ 9000 Series..
- N/A
Release Highlights:
- N/A
Release Highlights:
The following user(s) said Thank You: mdm, EdgarZ
3 weeks 6 days ago
AMD released AMD Ryzen™ Master 3.1.2.5621 on November 2, 2026 for Ryzen 5000 and later
Release Highlights:
Release Highlights:
Release Highlights:
Release Notes: www.amd.com/en/resources/support-article...EN-MASTER-3-1-2.html
Release Highlights:
- N/A
Release Highlights:
- N/A
Release Highlights:
The following user(s) said Thank You: mdm, fikotr74
