  • Tom's Avatar Topic Author
2 years 2 days ago
Release Highlights:
  • Adds an upgraded stress test (activated through the features 'Apply & Test' or 'Curve Optimizer Automatic')
  • DF P-state information is provided in the Home view
  • In IRM control mode, users can now adjust the PBO parameters (EDC, TDC, and PPT) up to the IRM limits
  • In Manual control mode, CPU speed can be adjusted in steps of 5 MHz
  • An advertisement banner has been incorporated, providing information on AMD products
  • This build now has support for 800 series AMD Socket AM5 Chipsets
Fixed Issues:
  • N/A
Known Issues:
Release Highlights:
Release Notes:
www.amd.com/en/resources/support-article...TER-2-14-2-3341.html
Re: AMD Ryzen™ Master Overclocking Utility
AMD released AMD Ryzen™ Master v3.0.0.4199 on July 23, 2025 for Ryzen 9000 Series Processors
v2.14.2.3341, November 20, 2024, for Ryzen 3000 Series to Ryzen 8000 Processors
2.13.1.3097, May 28, 2024, for Ryzen 2000 series processors and earlier
For Ryzen 9000 Series processors
Release Highlights:
  • Adds support for systems utilizing AMD Ryzen™ Threadripper PRO 9000 WX-Series Processors for the TRX50/WRX90 platform
  • Adds support for systems utilizing AMD Ryzen™ 9000 Series Desktop processors for the AM5 platform
  • Added support for Optimized Performance Profile (OPP) - an optimized memory overclocking profile for supported memory configurations
  • Switching to PBO Advanced control mode is on-the-fly (does not require a system restart)
  • Added support for the Per CCD Curve Optimizer feature
  • A completely redesigned UI for a better user experience
    • Workspace for viewing and modification of system settings in real-time (no need to switch to a Profile for applying changes)
    • Multiple Profiles can be created and saved with each one optimized for a particular workload
    • Auto Overclock to automatically adjust CPU and RAM to predefined overclocked settings
    • Flexible option to focus on individual CCD or multiple CCDs at once in the Dashboard
    • Smart Stress Test that performs stress test on CPU, RAM, or both, reflecting the adjustments made in the Tuning
Fixed Issues:
  • N/A
Known Issues:
  • Localization is not included but is work in progress. Future updates will include support for localization
  • The application may take a bit longer to load on systems with higher core count CPUs
  • In certain scenarios, when Ryzen Master is launched from AMD Software: Adrenalin Edition™, Ryzen Master Dashboard may not display accurate metric values. As a workaround, restart your system, and then launch Ryzen Master before starting AMD Software: Adrenalin Edition™.
For Ryzen 3000 Series to 8000 Series processors
Release Highlights:
Fixed Issues:
  • N/A
Known Issues:
For Ryzen 2000 series processors and earlier
Release Highlights:
Release Notes: www.amd.com/en/resources/support-article...es--3-0-0-4199-.html
Download: download.amd.com/Desktop/amd_ryzen_master_3_0_0_4199.exe
Release Notes:
Last edit: 1 year 4 months ago by Tom. Reason: Separating the different versions for different processors
11 months 11 hours ago
AMD released AMD Ryzen™ Master v3.0.1.4819 on December 9, 2025 for Ryzen 7000 and later
v2.14.2.3341, November 20, 2024, for Ryzen 3000 Series to Ryzen 5000
2.13.1.3097, May 28, 2024, for Ryzen 2000 and earlier
Ryzen 7000 Series and later:
Release Highlights:
  • The newer GUI introduced in the last release is now applicable to AMD Ryzen™ 7000 Series processors and beyond
  • Localization support available for languages German, French, and Simplified Chinese
  • Added support for DDR Nitro Mode – advanced memory tuning feature for high-frequency DDR5 modules to boost performance
Fixed Issues:
  • N/A
Known Issues:
Ryzen 3000 Series to 5000:
Release Highlights:
Fixed Issues:
  • N/A
Known Issues:
Ryzen 2000 and earlier:
Release Highlights:
Ryzen 7000 and later:
Release Notes: www.amd.com/en/resources/support-article...EN-MASTER-3-0-1.html
Download: www.amd.com/en/products/software/ryzen-master.html#download
Release Notes:
8 months 1 week ago - 8 months 1 week ago
AMD released AMD Ryzen™ Master v3.0.2.5029 on March 3, 2026 for Ryzen 5000 and later
v2.14.3.5040, March 13, 2026, for Ryzen 3000 Series to Ryzen 4000
Ryzen 5000 Series and later:
Release Highlights:
  • The newer GUI introduced in the last release is now applicable to AMD Ryzen™ 5000 Series processors and beyond
Fixed Issues:
  • N/A
Known Issues:
Ryzen 3000 Series to 4000:
Release Highlights:
  • Adds support for AMD Ryzen™ 3000 series to AMD Ryzen™ 4000 series processors
Fixed Issues:
  • N/A
Known Issues
Release Highlights:
Ryzen 5000 and later:
Release Notes: www.amd.com/en/resources/support-article...EN-MASTER-3-0-2.html
User Guide:  docs.amd.com/r/en-US/68886-ryzen-master-user-guide
Release Notes:
www.amd.com/en/resources/support-article...TER-2-14-3-5040.html
Last edit: 8 months 1 week ago by Tom.
  • PeterBeaumont
  • PeterBeaumont's Avatar
Release Highlights:
Fixed Issues:
  • N/A
Known Issues:
Release Highlights:
Fixed Issues:
  • N/A
Known Issues
Ryzen 2000 and earlier: слоты в казино win.casino
Release Highlights:
Release Notes:
good to see they’re still maintaining separate branches per gen, but that stress test inconsistency is a bit concerning if you rely on it for stability checks
Last edit: 6 months 1 week ago by PeterBeaumont.
Time to create page: 0.030 seconds
