  • Tom's Avatar Topic Author
1 year 4 months ago
#2042
AMD released v2.12.1.2806 on November 27, 2023
Release Highlights:
  • Adds support for systems utilizing AMD Ryzen™ Threadripper™ 7000 Series Processors and AMD Ryzen™ Threadripper™ PRO 7000 WX-Series Processors.
  • Memory overclocking support for AMD A620A Chipset based motherboards.
  • Telemetry voltage reporting
Fixed Issues:
  • None
Known Issues:
  • Bug reporting feature within Ryzen Master may not work on certain systems.
Release Notes: www.amd.com/en/support/kb/release-notes/...n-master-2-12-0-2806
1 year 1 month ago
#2430
AMD released v2.13.0.2908 on February 12, 2024
Release Highlights:
  • Adds support for systems utilizing AMD Ryzen™ 8000G Series desktop processors for the AM5 platform
  • Curve Optimizer values can now also be applied on the fly (no need for system restart)
Fixed Issues:
  • None
Known Issues:
  • None
Release Notes: www.amd.com/en/support/kb/release-notes/...n-master-2-13-0-2908
10 months 1 week ago
#2932
AMD released v2.13.1.3097 on May 28, 2024
Release Highlights:
Fixed Issues:
  • None
Known Issues:
  • None
Download: download.amd.com/desktop/amd-ryzen-master.exe
#3299
AMD released v2.14.0.3205 on August 8, 2024 (v2.13.1.3097, May 28, 2024)
Release Highlights:
  • New features introduced (applicable to select CPUs)
  • DF P state information is provided in the Home view
  • In IRM control mode users can adjust the PBO parameters (EDC, TDC, and PPT) up to the IRM limits but not exceeding them
  • In Manual control mode CPU speed can be adjusted in steps of 5 MHz
  • An advertisement banner has been incorporated, providing information on the AMD products
Fixed Issues:
  • N/A
Known Issues:
Release Highlights:
Release Notes:
www.amd.com/en/resources/support-article...TER-2-14-0-3205.html
Download: download.amd.com/Desktop/amd-ryzen-master-2-14-0-3205.exe
Last edit: 7 months 3 weeks ago by Tom.
6 months 1 week ago
#3637
AMD released v2.14.1.3286 on October 1, 2024 (v2.13.1.3097, May 28, 2024)
Release Highlights:
Fixed Issues:
  • N/A
Known Issues:
Release Highlights:
Release Notes:
www.amd.com/en/resources/support-article...TER-2-14-1-3286.html
Download: download.amd.com/Desktop/amd-ryzen-master-2-14-1-3286.exe
