  • Tom's Avatar Topic Author
  • Online
4 months 1 week ago
#3969
Release Highlights:
  • Adds an upgraded stress test (activated through the features 'Apply & Test' or 'Curve Optimizer Automatic')
  • DF P-state information is provided in the Home view
  • In IRM control mode, users can now adjust the PBO parameters (EDC, TDC, and PPT) up to the IRM limits
  • In Manual control mode, CPU speed can be adjusted in steps of 5 MHz
  • An advertisement banner has been incorporated, providing information on AMD products
  • This build now has support for 800 series AMD Socket AM5 Chipsets
Fixed Issues:
  • N/A
Known Issues:
Release Highlights:
Release Notes:
www.amd.com/en/resources/support-article...TER-2-14-2-3341.html
Time to create page: 0.073 seconds
