Intel Management Engine (ME) Firmware 16.1.42.2872 Consumer LP 1.5Mb
  • Castillot
  • Castillot's Avatar Topic Author
2 months 4 weeks ago - 2 months 4 weeks ago
Hi!
Is there another Intel Management Engine (ME) Firmware 16.1.42.2872 Consumer LP 1.5Mb Production. I downloaded the available version from station-drivers but got this error: 'Error 366: Failed to verify signature of OEM or RoT key manifests. For example: Error on update from Production to Pre-Production.'
Here is the ME info from my Lenovo Neo 50a 24 Gen 5 Desktop (ThinkCentre) - Type 12SC:
    Platform Type                                Mobile
    FW Image Type                                Production
    Last ME Reset Reason                         Other
    BIOS Boot State (EOP)                        Post Boot
    BIOS Boot State (CBD)                        Post Boot
    Boot Critical Code Redundancy                Disabled
    Current Boot Partition                       1
    OEM Chipset Init                             Available
    OEM Chipset Init Version                     12.0.5121.65535
    Factory Defaults Restoration Status          Disabled
    CPUID                                        0xB06A2
    Factory Defaults Recovery Status             Enabled
    Firmware Update OEM ID                       4C656E6F-766F-0000-0000-000000000000
    Intel(R) ICPS SW SKUing Eligible             Disabled
    Camera privacy feature control disabled      True
    Crypto HW Support                            Enabled
    Intel(R) ISH Power State                     Disabled
    OEM Tag                                      0x00
    FW Update State                              Enabled
    TLS State                                    Enabled
    CSME Measured Boot to TPM                    Disabled
    BIOS Recovery State                          Enabled
Intel(R) ME Code Versions
    BIOS Version                                 O6AKT28A
    MEI Driver Version                           2603.9.4.0
    FW Version                                   16.1.40.2765 LP Consumer
Extended Platform Services
    License Installed                            False
    License Period                               0 Periods
IUPs Information
    PMC FW Version                               160.1.0.1031
    OEM FW Version                               0.0.0.0000
    IOM FW Version                               36.7.0.0000
    NPHY FW Version                              14.531.509.8259
    TBT FW Version                               16.1.35.2303
    PCHC FW Version                              16.1.0.1014
PCH Information
    PCH Name                                     ADL
    PCH Device ID                                519D
    PCH Revision ID                              A1
    PCH SKU Type                                 Production PRQ Revenue
    PCH Replacement State                        Disabled
    PCH Replaceable Counter                      0
    PCH Unlocked State                           Disabled
Transactional FW Information
    Original image type                          Consumer
    Current sku type                             Consumer
Flash Information
    Storage Device Type                          SPI
    SPI Flash ID 1                               EF4017
    SPI Flash ID 2                               207018
    RPMC                                         Supported
    RPMC Bind Counter                            1
    RPMC Bind Status                             Post-bind
    RPMC Rebind                                  Supported
    RPMC Replay Protection Max Rebind            15
    BIOS Read Access                             0x000F
    BIOS Write Access                            0x000A
    GBE Read Access                              0x0009
    GBE Write Access                             0x0008
    ME Read Access                               0x000D
    ME Write Access                              0x0004
    EC Read Access                               0x0101
    EC Write Access                              0x0100
FW Capabilities                                  0x31309200
    Intel(R) Protected Audio Video Path          Present/Enabled
    Intel(R) Dynamic Application Loader          Present/Enabled
    Intel(R) Platform Trust Technology           Present/Enabled
    Persistent RTC and Memory                    Present/Enabled
End Of Manufacturing
    NVAR Configuration State                     Locked
    EOM Settings                                 Lock(Flash,Config)
    EOM Flow                                     Full
    HW Binding State                             Enabled
    Flash Protection Mode                        Protected
    FPF Committed                                Yes
    PAVP State                                   Yes
Security Version Numbers
    Trusted Computing Base SVN                   1
    Firmware Version Control SVNs
        PMC                                      0   [minimum allowed: 0]
        CSE                                      6   [minimum allowed: 0]
        ROT KM                                   0   [minimum allowed: 0]
        IDLM                                     0   [minimum allowed: 0]
        CSME bootstrap                           0   [minimum allowed: 0]
        SECURE BOOT BSMM                         1   [minimum allowed: 0]
        OEM KM                                   0   [minimum allowed: 0]
        SECURE BOOT KM                           1   [minimum allowed: 0]
        UCODE                                    1   [minimum allowed: 0]
        SECURE BOOT ACM                          2   [minimum allowed: 0]
HW Glitch Detection                              0x18C9
    TRC Polarity                                 Rising Trans
    TRC Mode                                     Full-cycle polarity trans
    TRC State                                    Enabled
    Intel(R) PTT initial power-up state          Enabled
    Intel(R) PTT State                           Enabled
    SMx State                                    Enabled
    RSA1K Support                                Disabled
Debug Information
    Token Present                                No
    Token Handling Status                        Not Available
    Invalid Knob Detected                        Not Available
    Consent                                      No
    DFx Policy                                   Unprivileged Public Debug Enabled
FW Supported FPFs                                FPF         UEP
                                                 *In Use
1st OEM Key Hash Revoked                         Disabled    Disabled
1st OEM Key Hash size                            Enabled     Enabled
1st OEM RSA Key size                             Enabled     Enabled
2nd OEM Key Hash Revoked                         Disabled    Disabled
2nd OEM Key Hash size                            Enabled     Enabled
2nd OEM RSA Key size                             Enabled     Enabled
BSMM Firmware Version Control                    Enabled     Enabled
CSE FW Firmware Version Control                  Enabled     Enabled
CSME Bootstrap Firmware Version Control          Enabled     Enabled
DNX Firmware Version Control                     Enabled     Enabled
Error Enforcement Policy 0                       Enabled     Enabled
Error Enforcement Policy 1                       Enabled     Enabled
Flash Descriptor Verification                    Disabled    Disabled
Glitch Detection Disabled                        Enabled     Enabled
IDLM Firmware Version Control                    Enabled     Enabled
Intel PTT Encryption Key                         Not Revoked Not Revoked
Intel(R) Manageability HW Fuse Status            Enabled     Enabled
Intel(R) PTT                                     Enabled     Enabled
OEM ID                                           0x00        0x00
OEM KM Firmware Version Control                  Enabled     Enabled
OEM Key Manifest                                 Enabled     Enabled
OEM Key Revocation State                         Disabled    Disabled
OEM Platform ID                                  0x00        0x00
OEM Secure Boot Policy                           0x6F        0x6F
CPU Debugging                                    Disabled    Disabled
BSP Initialization                               Disabled    Disabled
Protect BIOS Environment                         Enabled     Enabled
Measured Boot                                    Disabled    Disabled
Verified Boot                                    Enabled     Enabled
Key Manifest ID                                  0x01        0x01
Force Boot Guard ACM                             Enabled     Enabled
OEM key Hash RSA key size                        Enabled     Enabled
PID Refurbish Counter                            0x00        0x00
PMC Firmware Version Control                     Enabled     Enabled
PTT Lockout Override Counter                     0x00        0x00
Persistent PRTC Backup Power                     Enabled     Enabled
ROT Firmware Version Control                     Enabled     Enabled
RPMB Monotonic Counters                          0x00        0x00
RPMC Over EC                                     Disabled    Disabled
RPMC Rebinding                                   Enabled     Enabled
RPMC Support                                     Enabled     Enabled
SOC Config Lock State                            Enabled     Disabled
SPI Boot Source                                  Enabled     Enabled
SPIRAL CPU                                       Enabled     Enabled
Secure boot KM Firmware Version Control          Enabled     Enabled
TXT Supported                                    Disabled    Disabled
UFS Boot Source                                  Disabled    Disabled
uCode Firmware Version Control                   Enabled     Enabled
DNX SVN                                          0x00        0x00
IDLM SVN                                         0x00        0x00
OEM KM SVN                                       0x00        0x00
PMC SVN                                          0x00        0x00
ROT KM SVN                                       0x00        0x00
Secure boot ACM SVN                              0x00        0x00
Secure boot BSMM SVN                             0x00        0x00
Secure boot KM SVN                               0x00        0x00
Ucode SVN                                        0x00        0x00
Intel (R) FW Update Version: 16.1.38.2681
Copyright (C) 2005 - 2025, Intel Corporation. All rights reserved.
Checking firmware parameters...
Warning: Do not exit the process or power off the machine before the firmware update process ends.
Sending the update image to FW for verification:  [ COMPLETE ]
                        Do not Interrupt
Error 369: Failed to verify signature of OEM or RoT key manifests. For example: Error on update from Production to Pre-Production.
Last edit: 2 months 4 weeks ago by Castillot.
