yes i turned the psu off for 30 seconds and tried powering it when it was off to drain the caps
I tested the Z390 Aorus Master + 9900K for power off which was fine
but card 2 on a Z690 Aorus Elite AX + 12900k i hadnt i have just tested that
was powered off for 20 mins also fine
really i was expecting unique var's in the firmware
  • hu4567
  • hu4567's Avatar
very strange that 1.5.42 is working for your card but not mine.
can you maybe provide a dump of that card with that version? or the image file you flashed?
I already have
humor me
Fenvi AQC113C\AQC113C 1.3.21 Fenvi Factory Dump
run factory.bat
power down
when you power back up
Fenvi AQC113C\AQC113C 1.5.42 Fenvi DirtyWake ASPM Enabled
run update.bat
power down
you can see me in the video go through it including powering the pc fully down on 1.5.42 on both nic's
  • hu4567
  • hu4567's Avatar
yeah no. doesn't work. seems like my card simply doesn't like 1.5.42 ... at least not with these mac/phy values.
maybe my second card would work, but i don't risk it. would be a big hassle to remove it for recovery...
I picked up a newer revision
Its PCIE 4.0 x 4 not 3.0 x2
Loaded bundle: 1.5.38
NICGIGA REV2.0 GiGaPlus Rev 2.0
Fenvi / NICGIGA REV1 GiGaPlus Rev 1
FourPartIDs:0x1D6A:0x14C0:0x1D6A:0x0001
REV 1.0 PCIE 3.0 x2 Firmware 1.3.21 NO WOL AQC113C
REV 1.0 AQC113C
REV 2.0 AQC113
