- FirstEver
UPDATE
Universal Intel Wi-Fi and Bluetooth Drivers Updater now supports Intel Wi-Fi Driver 24.60.0.3
Thank you atplsx
The latest Intel Wi-Fi driver database: intel-wifi-driver-latest.md
Thank you atplsx
Last edit: 4 months 3 weeks ago by FirstEver.
There's a mistake in your screenshot, though not sure from where is the sceenshot:
VEN_8086&DEV_7740&SUBSYS_00708086, VEN_8086&DEV_7740&SUBSYS_00748086, VEN_8086&DEV_7740&SUBSYS_00788086 and VEN_8086&DEV_7740&SUBSYS_007C8086 belong to AX201 and not AX200.
It's labeled in the inf file as NIC_201_2x2_AX.
Last edit: 4 months 3 weeks ago by Tom.
- FirstEver
4 months 3 weeks ago - 4 months 3 weeks agoThank you Tom for reporting the HWID misidentification issue! 🙏There's a mistake in your screenshot, though not sure from where is the sceenshot:
Your feedback regarding DEV_7740 (with subsystems 0070, 0074, 0078, 007C) being incorrectly identified as AX200 (when it should be AX201) was spot on.
What was fixed:
Before: `DEV_7740` → **AX200** ❌
After: `DEV_7740` → **AX201** ✅
- The fix is already applied in the database: (` intel-wifi-driver-latest.md `)
Thanks again for catching this!
The following user(s) said Thank You: Tom, duttyend
- FirstEver
UPDATE
Universal Intel Wi-Fi and Bluetooth Drivers Updater now supports Intel Bluetooth Driver 24.60.0.4 and 24.40.11.1
Thank you @ atplsx
The latest Intel Bluetooth driver database: intel-bt-driver-latest.md
Thank you @ atplsx
Last edit: 4 months 2 weeks ago by FirstEver.
- FirstEver
3 months 2 weeks ago - 3 months 2 weeks ago
Update: 14/08/2026
I've just added new Intel Wireless Wi-Fi and Intel Wireless Bluetooth drivers to the updater database:
The Universal Intel Wi‑Fi & Bluetooth Drivers Updater code itself remains unchanged.
@atplsx – thanks for sharing the links!
- Intel Wireless Wi-Fi Drivers 24.70.0.3 (29/07/2026): intel-wifi-driver-latest.md
- Intel Bluetooth Drivers 24.70.0.4 (31/07/2026): intel-bt-driver-latest.md
Last edit: 3 months 2 weeks ago by FirstEver.
