Yeah i have an AX411 in one of my pc's so already knew what 0033 was
Im trying to find out what 0037 + 0038 is
Intel(R) Dual Band Wireless-AC 7260
USB\VID_8087&PID_07DC
Intel(R) Dual Band Wireless-AC 7265
USB\VID_8087&PID_0A2A
Intel(R) Wireless-AC 9260 160MHz
Intel(R) Wireless-AC 9560 160MHz
Intel(R) Wi-Fi 6 AX200 160MHz
USB\VID_8087&PID_0029&REV_0000
USB\VID_8087&PID_0029&REV_0001
Intel(R) Wi-Fi 6 AX201 160MHz
Intel(R) Wi-Fi 6E AX210 160MHz
Intel(R) Wi-Fi 6E AX211 160MHz
Intel(R) Wi-Fi 6E AX411 160MHz
Intel(R) Wi-Fi 7 BE200 320MHz
Intel(R) Wi-Fi 7 BE201 320MHz?
Intel(R) Wi-Fi 7 BE202 160MHz?
STP = Intel(R) Dual Band Wireless-AC 7265
THP = Intel(R) Wireless-AC 9260 160MHz
JFP = Intel(R) Wireless-AC 9560 160MHz
CCP = Intel(R) Wi-Fi 6 AX200 160MHz
HRP = Intel(R) Wi-Fi 6 AX201 160MHz
TYP = Intel(R) Wi-Fi 6E AX210 160MHz
GFP = Intel(R) Wi-Fi 6E AX211/AX411 160MHz
GAP = Intel(R) Wi-Fi 7 BE200 320MHz
??? = Intel(R) Wi-Fi 7 BE201 320MHz?
MTP = Intel(R) Wi-Fi 7 BE202 160MHz?
Last edit: 2 years 3 months ago by Shonk.
  • Vincy
  • Vincy's Avatar
0036, 0037, 0038 for new model WiFi-7 BE 200 (320MHz), BE 201 (320MHz, CNVio only), BE 202 (160MHz)
0037 BE 201 FMP "Filmore Peak"
Last edit: 2 years 3 months ago by Vincy.
The following user(s) said Thank You: Tom, duttyend
Its getting a chore remembering what card is in what pc..
Dell Vostro 3750 i3 2350M
Dell Vostro 3750 i7 2820QM
Fujitsu Lifebook A555 i5 5200U
Z390 M Gaming i7 8700K
HP Zbook Power G8 i9 11950H
Intel(R) Wi-Fi 6 AX201 160MHz (Soldered)
Firebat T8 Plus Intel N100
Z690 Aorus Master i9 12900K
Z690 Aorus Elite AX DDR4 Upstairs i9 12900K
Z690 Aorus Elite AX DDR4 Downstairs 19 13900K
Z390 Aorus Master i9 9900K
Im tempted to pickup a few more BE200's and upgrade the ones that can be upgraded
  • THEBOSS619
  • THEBOSS619's Avatar
Intel just limiting or locking Wi-Fi features through driver level. I have managed to make a AX210/AX211 to be a AX411 with all kind of features like DCT & NetAdapterCx driver support...
www.techpowerup.com/forums/threads/teste...11-wifi-chip.325408/
Already works on my AX211 which is basically a AX411. They share the same HW spec.... Same thing applies for AX1650 I upgraded the driver to be a AX1690 bec. they also share the HW spec...
It's just Intel locking down features through driver level to force you to buy the new WiFi chip/cards.
The following user(s) said Thank You: admin, duttyend, surang
  • Tom's Avatar
I have a  reference in the WiFi 23.70.3.1 driver for BE202 as MTP ,and the BE201 is listed as FMP.
The following user(s) said Thank You: duttyend, Shonk
