Intel I226–LM/ V/ IT Lan Controllers Firmware Version 2.27
First firmware for the I226 series of network chipsets, version 2.27, dating from 2024
NVMUpdate version 1.41.3.1
Copyright(C) 2013 - 2024 Intel Corporation.
nvmupdatew64e.exe -i -l inventory.txt
Config file will not be read.
Inventory
[00:133:00:00]: Intel(R) Ethernet Controller I226-V
Flash inventory started.
Shadow RAM inventory started.
Flash inventory finished.
Vendor : 8086
Device : 125C
Subvendor : 1043
Subdevice : 8867
Revision : 6
LAN MAC : xxxxxxxxxxxx
Alt MAC : 000000000000
SAN MAC : 000000000000
ETrackId : 8000039D
SerialNumber : A0AD9FFFFFA10858
NVM Version : 2.35(2.23)
PBA : G23456-000
VPD status : Not set
VPD size : 0
checksum : Valid
Upon checking my chipset, I noticed that mine is newer and therefore doesn't require an update, but for those interested, here is the download link below.
For Windows & Linux
www.station-drivers.com/index.php/en/com...ion-2.27/lang,en-gb/
Inventory
Vendor : 8086
Device : 125C
Subvendor : 1043
Subdevice : 8867
Revision : 6
ETrackId : 8000039D
PBA : G23456-000
VPD size : 0
checksum : Valid
For Windows & Linux
- jumpy76
Re: Intel I226–LM/ V/ IT Lan Controllers Firmware Version 2.27
7 months 2 weeks ago
Thank you very much! How to check the LAN firmware version? Any help on the flash? There are different bin and no executable file.
Hi, download the latest Intel Network Pack; the necessary files are in the NVM directory.
Intel Nework 31.1
www.station-drivers.com/index.php/en/com...ion-31.1/lang,en-gb/
Alternatively, run the command `nvmupdatew64e.exe -i -l inventory.txt`.
To update, simply change the firmware of the NVM directory in the Intel network pack and replace it with the one you want.
Intel Nework 31.1
Last edit: 7 months 2 weeks ago by admin.
