Intel Management Engine (ME) Firmware Version 19.0.5.1984 (S&H 1.5Mo)
Release note: Intel has identified security issue that could potentially place impacted platform at risk.
Check your vulnerability with the Intel utility below which allows you to check if you have the latest Management Engine (ME) firmware and if you are vulnerable
  • tecklord
  • tecklord's Avatar
Re: Intel Management Engine (ME) Firmware Version 19.0.5.1984 (S&H 1.5Mo)
Hi all!
Beware of this ME Update... on my systems it was of no good use.
ASRock PG Riptide Z890M [BIOS 3.03] - Ring/Cache settings were not applied as entered in BIOS
Gigabyte Z890 Aorus Elite [BIOS F17b] - NGU and Ring/Cache settings were not applied
Had to use USB BIOS Flashbacks to get rid of it.. will wait for official BIOS version with it contained for now..
Thanks​
Sebastian
Last edit: 1 year 6 months ago by tecklord. Reason: Linebreaks were not converted
No particular issues with my Gigabyte Z890 Master so far
This update fixes security vulnerabilities
If anyone else has any problems, please don't hesitate to ask.
1 year 6 months ago
There are two versions, either T or S.
Mine is T.
If in doubt, wait for the official version of your motherboard.
