Intel Management Engine Firmware for B460 chipset
  • rvail
  • rvail's Avatar Topic Author
3 months 4 days ago
The description for Intel Management Engine Firmware appears to be incorrect for B460 chipset motherboards.
Intel Management Engine (ME) Firmware Version 14.1.80.2616 (S&H)(1.5Mo)(dated 25 Aug 2026) indicates inclusion of B460: (incorrect).
www.station-drivers.com/index.php/en/com...)(1.5Mo)/lang,en-gb/
Except, for my Gigabyte B460-HD3 motherboard, the factory-installed ME firmware was version 14.5.x, and has since been successfully updated to version 14.5.45.1763, dated 23 MAY 2022.
www.station-drivers.com/index.php/en/com...e-14.5.x/lang,en-gb/
As noted, the 14.1.x firmwares have seen numerous security updates. The B460 series should be getting security updates, but nothing since 23 MAY 2022.
Re: Intel Management Engine Firmware for B460 chipset
3 months 4 days ago - 3 months 4 days ago
Hi, thanks for the info. Yes, there are two versions—14.x and 14.5—so it depends on the specific version; that’s why you should always check the series.
Intel Comet Lake-V (14.5.xxxx)
Intel Comet Lake (14.x.xxxx)
Always check via Device Manager or the Intel utility below.
Intel® Converged Security and Management Engine Version Detection Tool
Last edit: 3 months 4 days ago by admin.
