1 year 2 weeks ago - 1 year 2 weeks ago
--  BEFORE  --
--  AFTER  --
To access and modify the firmware link, please enter the password
Password: asmedia
External Thunderbolt 4 USB-C enclosure on USB-C Thunderbolt 4 DOCK output of the Gigabyte Z890 Master motherboard
Download:
Last edit: 1 year 2 weeks ago by admin.
The following user(s) said Thank You: Shonk, fikotr74, rebootbee
  • programervn
  • programervn's Avatar
Re: Asmedia ASM2464 NVME/USB 4.x Controller Firmware Version 250717_85_00_00
1 year 6 days ago
hi @admin
which is the difference between "Version 250717_85_00_00 & 250717_00_00_00" and "Version 231005_85_02_03"?
I found two drivers as below
www.station-drivers.com/index.php/en/com...own/6815/lang,en-gb/
www.station-drivers.com/index.php/en/com...85_02_03/lang,en-gb/
The following user(s) said Thank You: rebootbee
1 year 6 days ago
Hello Version 250717_85_00_00 which always ends up as 85.00.00 is specially designed for USB4/Thunderbolt external enclosures and Version 00.00.00 is specially designed for PCI-E conversion devices such as USB4/PCI-E adapters
The following user(s) said Thank You: Galixte, programervn
  • Galixte
  • Galixte's Avatar
11 months 3 weeks ago
Salut,
Sais-tu pourquoi le PRODUCT ID est défini sur 2463 alors que le chipset est un ASM2464PD ?
Salut,
Bonne question car moi aussi je comprend pas surement que la Serie  ASM2464 fait partie ?
