- rebootbee
9 months 2 weeks ago
Hi that ORICO USB4 cable 1 meter looks super thick, have you been using it for a long time and how has the stability been overall? Any issues with detection, freezing or crashing or suddenly cutting out with no detection etc
I found 0.5 metre Thunderbolt 4/5 certified cables from cable matters and others to still be unstable, they may work on the 4-5 time but on 6-7th they can not detect the drive or become unstable, they were thick but not as thick as that orico from looks.
The following user(s) said Thank You: rebootbee
- misal1337
- Poster
9 months 6 days ago - 9 months 6 days ago
Hello, I have ShuoLe ASM2464 NVMe enclosure from Aliexpress. I inserted Crucial P3 2TB Plus into it. Works damn good. But if I connect it to USB 4 port of my Asus X870E ProArt motherboard, Rufus cannot detect the external drive. It only gets detected when connected to USB 3.2 20G or 10G ports. I checked the USB drives option in Rufus.
Secondly, when I try to boot my drive with Ventoy installed and Strelec Boot PE iso, it boots into it but fails to mount the drive containing recovery apps when plugged into USB 4 port. This issue does not happen on USB 3.2 20G or 10G ports.
Tried upgrading as well as downgrading ASM2464 frimware. I also tried downgrading BIOS, changing cables. But this is USB4 port problem.
Any solution?
www.banggood.in/ShuoLe-SL-TP4001-USB4-M_...ehouse=CN&ID=6287832
Any solution?
Last edit: 9 months 6 days ago by misal1337.
9 months 5 days ago - 9 months 5 days ago
Hi, have you updated the firmware of the USB4 (Asmedia) port + port PD ?
ASUS 4242 and PD-GX Firmware Windows Update Tool
ProArt X870E-CREATOR WIFI|Cartes mères|ASUS France
Last edit: 9 months 5 days ago by admin.
- Stasiz
- poster 5
9 months 5 days ago
The following user(s) said Thank You: misal1337, rebootbee
