Realtek RTL9210B NVMe/USB 3.1 Controller firmware Version 1.33.98.090324
The update allows an increase in speeds both in writing and in reading and works perfectly on my Asus TUF A1 it is rare to see a firmware bring so much difference
The gains made are due to improved support for certain SSDs.
www.station-drivers.com/index.php/en/com...8.090324/lang,en-gb/
Last edit: 3 months 1 week ago by admin.
The following user(s) said Thank You: Shonk, AOnurY, leon22heart
Re: Realtek RTL9210B NVMe/USB 3.1 Controller firmware Version 1.33.98.090324
3 months 1 week agoConfiguration
3 months 1 week ago
thanks i have been wondering when we will get 1.33.98 that
AOnurY
mentioned a while ago
did someone dump it or an oem release it?
3 months 1 week ago
It is a manufacturer who publishes it
3 months 1 week ago
On my side better compatibility and therefore better performances with certain SSD no name because those of big brands the performances are similar.
Have you also noticed differences
