ssd Asmedia ASM2464 NVME/USB 4.x Controller Firmware Version 241129_85_00_00
3 months 2 weeks ago - 3 months 5 days ago
#4081
New Z890 TBT 4
Personally, little gain on my XG7000 compared to the old version but certainly better compatibility
www.station-drivers.com/index.php/en/com...85_00_00/lang,en-gb/
Last edit: 3 months 5 days ago by admin.
The following user(s) said Thank You: Stuart_L
Re: Asmedia ASM2464 NVME/USB 4.x Controller Firmware Version 241129_85_00_00
#4100
It gave me an error at first cannot flash PDX to PD or something like that
closed it and re opened it and it flashed fine that time
#4101
Yes I had the same problem the first time the update failed then the 2nd time it was flawless
  • Stuart_L
  • Stuart_L's Avatar
#4104
Thank you for posting this!
Is that the Satechi USB4 NVMe SSD PRO Enclosure that you updated?
Best regards,
Stuart
3 months 2 weeks ago - 3 months 2 weeks ago
#4106
No it's the Ugreen below
Last edit: 3 months 2 weeks ago by admin.
