7 months 1 week ago
#3392
Hi, can't you make a backup to share the firmware?
7 months 1 week ago - 7 months 1 week ago
#3393
the backup tool doesnt work as the firmware is 96k instead of the expected 64k
so it gets confused we need to ask Ochkin Vadim the guy who made the tool
to add support for ASM2464 but im unsure how to contact him
I think he's on russian forums
my russian is not good..
His webserver with all his tools is here
vlo.name:3000/ssdtool/
but i cant see any way to contact him
he's on here as username vlo for example
forum.ixbt.com/topic.cgi?id=11:45048-169
Last edit: 7 months 1 week ago by Shonk.
7 months 1 week ago
#3395
to have a better flow I use the Thunderbolt 4 of my motherboard
7 months 1 week ago
#3397
My HP ZBook Power 15.6 G8 has an i9-11950H
the specs state
USB Type-C port with Thunderbolt 4, pass through support DispalyPort 1.4, USB 3.2 Gen 2, with BC 1.2 support
Im not really sure whats going on with the port
#3398
Yes, it's strange to have you checked via the HSA, I know that you know the material, so no need to tell you that the cable is a lot, as is the length.
