7 months 1 week ago - 7 months 1 week ago
#3399
This is my guess at the problem
hence why im blaming the laptop
i may be able to force the asm2464 into another mode which may or may not help
but dont want to mess with the firmware until i get a backup somehow
Last edit: 7 months 1 week ago by Shonk.
7 months 1 week ago
#3400
7 months 1 week ago
#3401
I have heard of some devices handshaking oddly if the device is gen4
#3403
i can't tell you because I only have REALTEK RTL9210,  ASMEDIA ASM2464 & 2364 & 2362
Of course the fastest is the ASM2464 because of the Thunderbolt port (USB4)
#3404
i presume it will resolve with newer firmware or fitting a gen3 drive to it
will update in a few weeks/months when i resolve it
3.2 Gen2 x2 works fine
3.2 Gen2 x1 also fine
