Asmedia ASM2464 NVME/USB 4.x Controller Firmwares
1 year 1 week ago - 1 year 2 days agoFIRMWARES ASM-2464
Asmedia ASM2464 NVME/USB 4.x Controller Firmwares:
Version: 240229_85_00_00
Release note:
Last edit: 1 year 2 days ago by admin.
1 year 3 days ago - 1 year 2 days ago
SSD nvme 1To (FIKWOT_FN955) suir un boitier USB 4.x/Thunderbolt 4 (Asmedia ASM2464) avec le dernier firmware
Speedtest USB 3.2 Gen 1 (10Gbps)
Speedtest USB 3.2 Gen 2x2 (20Gbps)
Speedtest USB 4.x (Thunderbolt 4) (40Gbps)
Attention ! Pour un meilleur débit, veuillez bien vérifier que le raccordement sur le port USB-C et bien en USB 4.x ou Thunderbolt 4
Connection USB 3.0 (5Gbps)
Connection USB 3.2 X1 (10Gbps)
Connection USB 3.2 X2 (20Gbps)
Connection USB 4/Thunderbolt 4 (40Gbps)
- nadja75
1 year 1 day ago
Good evening everyone, I'm a new user of this fantastic forum, and I've been the owner of a 256Gb MAC Air M2 for a few months.
Today I purchased yet another hdd case with the ASMedia ASM2464 chip on board, I'll include the link at the end of the post. As soon as I turned it on I proceeded to update the firmware to version AS_USB4_240129_85_00_00.bin.
Since the MPTool utility does not have backup functions for the old firmware and the configuration, I proceeded to take some screenshots, where the configuration is shown in a hex table.
Originally I had the firmware version AS_USB4_231005_85_02_03, which I believe is just a variant, perhaps not even real, of the firmware that can be found online AS_USB4_231005_85_00_00 which is mounted on the JEYI models
As expected immediately after the update, the case status LED began to not work properly.
For example, if connected to the TB4 port, it does not light up blue and remains only green as if it were connected to a USB 3.0 port.
During reading/writing, this does not flash as it should and remains lit steadily.
By modifying the ini file in the [PCIE_USB_Config] parameter - two_leds_enable=1 I managed to obtain the flashing during the reading phase but when connected to a USB 3.0 port, while if I connect it to a TB4 port, the LED turns on for a moment to green and then turns off.
Do you have any idea how to proceed to resolve the situation.
It is possible that it is not possible to use the ini file correctly, someone who has the same device could read the firmware contained in the flash with a programmer and pass it to me. I would like to restore the correct functioning of the LED.
The reseller has not yet provided me with any support, he simply wrote to me that it will be difficult to get hold of that file.
Thank you.
it.aliexpress.com/item/1005006255433150....gatewayAdapt=glo2ita
Thank you.
1 year 1 day ago - 1 year 1 day ago
Hi yes I think xlike you I think that the numbers after 85.xxxx allow customization or personalization of the firmware by the manufacturer.
Did you save the *.ini
file?
file?
Last edit: 1 year 1 day ago by admin.
- nadja75
11 months 4 weeks ago - 11 months 4 weeks ago
Hi, I saved the INI file, but it does not contain the customization of LED management.
I managed to find this in the pdf document that I attach, where it says that the dual LED function is only valid at the test level of the ASMEDIA laboratories.
When I modify this parameter, I can obtain the correct management of the LED only when it is connected to USB 3 ports, but when I connect the adapter to the Thunderbolts port of the MAC M2, the LED turns off directly as soon as it tries to switch to the second color. Needless to say, I tested the correct functioning of the LED. However, the two LED option was not set in the original firmware, as can be seen from the photo I attached to the previous post.
Last edit: 11 months 4 weeks ago by nadja75.
