AMD Ryzen Master Overclocking Utility v2.1x.x.xxxx
il y a 1 an 7 mois
AMD released v2.12.1.2806 on November 27, 2023
Release Highlights:
Release Notes: www.amd.com/en/support/kb/release-notes/...n-master-2-12-0-2806
Release Highlights:
- Adds support for systems utilizing AMD Ryzen™ Threadripper™ 7000 Series Processors and AMD Ryzen™ Threadripper™ PRO 7000 WX-Series Processors.
- Memory overclocking support for AMD A620A Chipset based motherboards.
- Telemetry voltage reporting
- None
- Bug reporting feature within Ryzen Master may not work on certain systems.
il y a 1 an 4 mois
AMD released v2.13.0.2908 on February 12, 2024
Release Highlights:
Release Notes: www.amd.com/en/support/kb/release-notes/...n-master-2-13-0-2908
Release Highlights:
- Adds support for systems utilizing AMD Ryzen™ 8000G Series desktop processors for the AM5 platform
- Curve Optimizer values can now also be applied on the fly (no need for system restart)
- None
- None
il y a 1 an 1 mois
AMD released v2.13.1.3097 on May 28, 2024
Release Highlights:
Download: download.amd.com/desktop/amd-ryzen-master.exe
Release Highlights:
- This update resolves the issue of certain CPU parameters being shown incorrectly after upgrading the BIOS on AM5 platform systems utilizing AMD Ryzen™ 8000G Series desktop processors
- None
- None
il y a 10 mois 3 semaines - il y a 10 mois 3 semaines
AMD released v2.14.0.3205 on August 8, 2024 (v2.13.1.3097, May 28, 2024)
Release Highlights:
Release Highlights:
Release Notes: www.amd.com/en/resources/support-article...TER-2-14-0-3205.html
Download: download.amd.com/Desktop/amd-ryzen-master-2-14-0-3205.exe
Release Highlights:
- Adds support for systems utilizing AMD Ryzen™ 9000 Series desktop processors for the AM5 platform
- New features introduced (applicable to select CPUs)
- Memory can be overclocked on-the-fly (applying EXPO profile does not require a system restart)
- Additional memory tuning parameters are introduced, providing further customization options for optimizing memory performance
- DF P state information is provided in the Home view
- In IRM control mode users can adjust the PBO parameters (EDC, TDC, and PPT) up to the IRM limits but not exceeding them
- In Manual control mode CPU speed can be adjusted in steps of 5 MHz
- An advertisement banner has been incorporated, providing information on the AMD products
- Support discontinued for AMD Ryzen™ and AMD Ryzen™ Threadripper™ 1000 and 2000 series processors
- N/A
- On some CPUs, stress test (activated through the features 'Apply & Test' or 'Curve Optimizer Automatic') might not fully stress the CPU or might require additional time to apply maximum stress. In such situations, consider increasing the stress test duration from the settings page
- There may be minor discrepancies between the duration specified by the user and the actual time required for the stress test to complete
Release Highlights:
il y a 9 mois 3 jours
AMD released v2.14.1.3286 on October 1, 2024 (v2.13.1.3097, May 28, 2024)
Release Highlights:
Release Highlights:
Release Notes: www.amd.com/en/resources/support-article...TER-2-14-1-3286.html
Download: download.amd.com/Desktop/amd-ryzen-master-2-14-1-3286.exe
Release Highlights:
- Adds support for 105W Eco Mode to systems utilizing AMD Ryzen™ 9000 Series 65W and 120W desktop processors
- N/A
Release Highlights:
