Intel® Ethernet Adapter Complete Driver Pack
  • Portrait de Tom Auteur du sujet
  • Absent
Re: Intel® Ethernet Adapter Complete Driver Pack
il y a 10 mois 4 semaines - il y a 10 mois 3 semaines
#2849
Intel released Intel® Ethernet Adapter Complete Driver Pack v29.1 WHQL on May 7, 2024
Download Page: www.intel.com/content/www/us/en/download...ete-driver-pack.html
Direct Download: downloadmirror.intel.com/822488/Release_29.1.zip (Size: 786 MB)
Release Notes: downloadmirror.intel.com/822488/Release_Notes.pdf
Changelog for v29.1:
New Hardware Support
• None for this release. Although Intel® 800 Series Ethernet Driver (AArch64) v4.2.34 option is presented in the BootUtil tool, ARM Servers are not supported in this release.
New Software Support
• Azure Stack HCI 23H2 OS support.
• RX Timestamp support on E810.
• Traffic Mirroring via tc-mirred on E810.
• Control FW debug logs level via debugfs on E810.
• Flexible VF loopback pacing configuration on E810.
• SyncE4L NIC chaining improvements on E810.
• PHY Statistics Dumps on E810.
• Devlink health support for Tx hang debugging on E810.
• HII VLAN function configuration support for E810 OEMGen devices.
• DMA_buf w/o ODP support for Linux RDMA.
• FreeBSD E810 - Count packets larger than RX MAX as Rx Oversize packets.
• Print NIC FW version on E810.
• FreeBSD X710 - Count packets larger than RX MAX as Rx Oversize packets.
• Log FW Failure Critical Data in Recovery Mode.
• NVMUpdate option to use FW Version to determine if update is upgrade or downgrade.
• Driver can provide debug log when TX unit hang occurs on E810.
• Set E810 debug level and UART option when driver is working.
• Enable E810 GPUDirect community solution: DMA_BUF without ODP.
New Firmware Support
• Enable E700 X722 Tx signal to “always on”.
• Enable E700 to store events details on the NVM in Recovery Mode.When entering the Recovery Mode, X710 will
store the details of the event in the NVM.
• Added native support for BIDI 100G PAM4 Compliance Code Modules (CAUI4 with No FEC).
• Added native support for 10GBaseT 80m module (SFP).
• Added to E810-CQDA2T adapters, 6 ports Mixed Mode 10G/25G.
• Added RDE properties for PortMetrics.Transceivers.
• Disable Optical Module Laser when Link/Port is disabled on E820.
• Allow I2C 2 byte write access for PHY control on E820.
Les utilisateur(s) suivant ont remercié: admin, mdm, grimson, duttyend
  • Portrait de admin
  • Absent
il y a 10 mois 4 semaines - il y a 10 mois 4 semaines
#2851
Thx Tom
New drivers I225/226
  • grimson
  • Portrait de grimson
#2852
Even the old i219 drivers got updated
  • Absent
il y a 10 mois 1 semaine
#2910
Intel released Intel® Ethernet Adapter Complete Driver Pack v29.1.1.1 WHQL on May 23, 2024
Direct Download: downloadmirror.intel.com/823672/Release_29.1.1.1.zip (Size: 785.9 MB)
Release Notes: downloadmirror.intel.com/823672/Release_Notes.pdf
Changelog for v29.1.1.1:
• None available for now.
Les utilisateur(s) suivant ont remercié: Ataemonus
  • Absent
il y a 7 mois 1 semaine
#3376
Intel released Intel® Ethernet Adapter Complete Driver Pack v29.3 WHQL on August 23, 2024
Direct Download: downloadmirror.intel.com/831137/Release_29.3.zip (Size: 818.6 MB)
Release Notes: www.intel.com/content/www/us/en/content-...s-release-notes.html
Changelog for v29.3:
• New OS support: FreeBSD 14.1
• OpenEuler ARM architecture compatibility
• Introduced ICE driver migration for Linux DPLL interface usage in kernel 6.7
• Devlink support for tools algorithm improvement
• Ethtool flow-type ether support
• 40G ESXi new default VMDq loopback behavior and module parameter
• Message logs related to Health Status 0x110 updated
• Disable Optical Module Laser when Link/Port is disabled on E810
• GET_LLDP type command : get all ports LLDP information on E810.
• Disabling of port 0 (as long it’s not associated with PF 0).
• Use Rx Loss to detect cable disconnect from Module on E810
• Expanding i2c write handling to enable 4 bytes on E810
Removed Features:
• UEFI UNDI AVF driver support.
• Removed 100G ESXi configuration of VMDq loopback via intcli
Les utilisateur(s) suivant ont remercié: admin, Ataemonus
