Firmware 1.94 (i225-V)
- oemuser
- Poster
Re: Firmware 1.94 (i225-V)
il y a 7 mois 1 semaine - il y a 7 mois 1 semaine
Probably due to settings in nvmupdate.cfg, that's why i linked the other i225 1.89 thread...to read if you care.
- ppanthagod
thx oemuser. ill try to reset adapter to default with .cfg file.
- Districtor
il y a 3 mois 2 joursFrom Dell :
EGW5200_I225_NVM_Update_v1.94_Windows.zip (1.94_IT_1G_LED_2MB_EGW5200)
Fixes & EnhancementsEnhancements
1. Integrate Intel Ethernet Non-Volatile Memory (NVM) Update for 2024.1 IPU.
Version 1.94, A00 Release date 08 May 2024
Can this update be used on the I225-V? Seems to be for the I225-IT. Would be interesting, as the 2MB version includes PXE functionality.
- Tadeo
il y a 2 mois 4 semaines
Can I use it to flash my integrated NIC on ASUS Strix Z590A ?
EEUPDATE v5.38.10.00
1 6 00 00 8086-15F3 Intel(R) Ethernet Controller (3) I225-V
1: EEPROM Image Version: 1.89
i7-11700K / ASUS Z590-A Strix/ Crucial Ballistix 64GB 3200 CL16 / XFX AMD RX 6800 16GB/ 2x SSD 970 Evo Plus 1TB and 2TB / PSU: NZXT C850 / DELL S3422DWG, Windows 11 22H2
- wiensha
il y a 4 semaines 1 jour
I would not advice to update to the modified firmware/EEPROM v1.94 for the i225-V 15F3 model.
Every time the system freezes after approx. 10 minutes watching YouTube streams in the Chromium browsers Edge or Chrome when the Graphic Acceleration was switch on in the browser system setting. Switching this off did resolve the problem, but the video stream was not as optimal. So, when I did go back to firmware v1.89 for the i225-V 15F3 model the problem was completely resolved and I could watch the YouTube video streams without any freezing in the Chromium browsers with Graphic Acceleration switch On in browsers settings.
