Hello everyone,
Fdrsoft
  • Vitaliy
  • Portrait de Vitaliy
il y a 1 an 8 mois
#1420
  • Absent
il y a 1 an 8 mois
#1421
Yes the last revision not bugged the I226-LM
  • Vitaliy
il y a 1 an 8 mois
#1424
Could you publish result of " EEUPDATEW64e.exe /nic=1 /eepromver >temp.txt " if it is vorking with I226?
Does it really work as 2.5G full duplex?
  • Absent
il y a 1 an 8 mois
#1426
I can't know because I just have 2 I225-LM Rev 3.0 & 2.0
  • EDU5K
  • Portrait de EDU5K
il y a 1 an 7 mois
#1444
my connection in online games seems worse with this firmware version, it seems like higher latency or something, something is wrong, what could it be? i have asus b550-e nic rev2.
Temps de génération de la page : 0.077 secondes
