- Andrew77
il y a 1 mois 2 semaines
Yay I made it
Now trying to re-flash old firmware from backup
- Andrew77
il y a 1 mois 2 semaines - il y a 1 mois 2 semaines
Weird - can't restore from backup, with or without NVRAM
I noticed that it is showing "Programming Fail!!" just before the device disconnects and app data is reset (see attached photo).
Maybe I should Erase All Flash Only?
yeah just erase it you can then boot from internal without shorting
then next time it should flash fine
Les utilisateur(s) suivant ont remercié: Andrew77
- Andrew77
Erase was successful, but it is no longer possible to successfully flash the device
Every file chosen yields "Programming Fail!!", the disconnect sound, then a reconnect sound and a "USB Device"
I can then immediately Erase again, and after re-powering the device it re-appears as "JMICRON JMS583" with Firmware Ver. "Internal code"
FYI I tried both the USB-C (my default) and the traditional USB cable, no avail
Dernière édition: il y a 1 mois 2 semaines par Andrew77. Raison: Added comment on the two different cables
Try turning off VBS + Secure boot
VBS you disable in windows Secure boot you do in the bios
