Hello everyone,
Fdrsoft
  • Portrait de admin
  • Absent
il y a 4 mois 2 semaines
#3921
Ok I look at the file, otherwise to unlock click on the key and enter "asmedia"
  • teomialo
  • Portrait de teomialo
  • Membre
  • Membre
il y a 4 mois 2 semaines - il y a 4 mois 2 semaines
#3922
thank you, it's unlocking.
with your new version, the flash PASS is worry free on USB 3.0 port ! great.
I put back the same PIDs as before. But the disk label is “test”, so how can I change it back to “NEW DISK”?
and the speed seems to work with this new firmware 200416_D1_48_02, as does the LED, which lights up again. thanks.
I have other ugreen boxes to flash, should I change the serial number or the PID or should I leave it as it is ?
[img
  • Portrait de admin
  • Absent
#3923
No need to change Id but you can put the name of the disk you want
Les utilisateur(s) suivant ont remercié: teomialo
  • teomialo
  • Membre
  • Membre
#3924
So I leave the same serial number, the same supplier and the same PID for all my Ugreen boxes ?
isn't there a risk of conflict in windows if I connect two devices at the same time ?
The reader label is grayed out, so it's impossible to change it (name test)
I also notice that when ejecting the disk, it doesn't respect the product string name “Ugreen Storage Device” (If I switch back to the original firmware, the product string name is correct)
How can we fix this ?
otherwise the writing speed is excellent with the 200416_D1_48_02.bin
[img
  • Portrait de admin
  • Absent
#3926
The serial number is not a problem, nor is the name, otherwise impeccable.
