  • ole258
  • Portrait de ole258
#3318
I need the external enclosure not very often, for lower datatransfers and sometimes I need to swap the SSD. At the moment I use a LEXAR E300 (RTL9210B) without any thermal pad on the SSD. For a short use, after swapping, I even use it with open case/cover.
Do you think it's also working in the Samget, without thermal pad? Without getting critical high temps.
Edit: May there is an another problem that I have not yet considered...to get 20 Gbps datatransfer USB3.2 2x2 is needed. I "only" have Thunderbolt 4 Ports (I read on some Amazon reviews, that it only works at 20 Gbps on a USB3.2 2x2 - for Thunderbolt 4 a 40 Gbps encosure is needed.). Does the ASM2364 deliver 20 Gbps on Thunderbolt 4 ports?
  • Portrait de Shonk
il y a 7 mois 2 semaines
#3319
You need asm 2464 for tb
Thunderbolt doesnt support USB 3.2x2 only 3.2x1
Les utilisateur(s) suivant ont remercié: ole258
  • ole258
#3323
The ASM2464 is much to expensive for my personal usage.
So I continue with the 10Gbps RTL9210B 👍
  • Portrait de Shonk
#3555
