Re: AMD Ryzen™ Master Overclocking Utility
6 months 1 week ago
Yes, and Intel does the same thing with Intel Extreme Tuning Utility
  • Tom's Avatar Topic Author
6 months 1 week ago
AMD released AMD Ryzen™ Master v3.1.0.5185 on May 11, 2026 for Ryzen 5000 and later
v2.14.3.5040, March 13, 2026, for Ryzen 3000 Series to Ryzen 4000
2.13.1.3097, May 28, 2024, for Ryzen 2000 and earlier
Ryzen 5000 Series and later:
Release Highlights:
  • Added support for the Curve Shaper feature – a fine‑grain voltage/frequency tuning capability that allows selective voltage adjustments across temperature and frequency bands; applicable to the AMD Ryzen™ 9000 Series.
Fixed Issues:
  • N/A
Known Issues:
  • The application may take a bit longer to load on systems with higher core count CPUs
  • In certain scenarios, when Ryzen Master is launched from AMD Software: Adrenalin Edition™, Ryzen Master Dashboard may not display accurate metric values. As a workaround, restart your system, and then launch Ryzen Master before starting AMD Software: Adrenalin Edition™.
Ryzen 3000 Series to 4000:
Release Highlights:
  • Adds support for AMD Ryzen™ 3000 series to AMD Ryzen™ 4000 series processors
Fixed Issues:
  • N/A
Known Issues
Ryzen 2000 and earlier:
Release Highlights:
Ryzen 5000 and later:
Release Notes: www.amd.com/en/resources/support-article...EN-MASTER-3-1-0.html
User Guide:  docs.amd.com/r/en-US/68886-ryzen-master-user-guide
Download: www.amd.com/en/products/software/ryzen-master.html#download
Release Notes:
www.amd.com/en/resources/support-article...TER-2-14-3-5040.html
The following user(s) said Thank You: mdm
4 months 2 days ago
AMD released AMD Ryzen™ Master v3.1.1.5502 on July 22, 2026 for Ryzen 5000 and later
Release Highlights:
  • Added support for the Curve Shaper feature – a fine‑grain voltage/frequency tuning capability that allows selective voltage adjustments across temperature and frequency bands; applicable to the AMD Ryzen™ 9000 Series..
Fixed Issues:
  • N/A
Known Issues:
Release Highlights:
Fixed Issues:
  • N/A
Known Issues
Release Highlights:
Release Notes: www.amd.com/en/resources/support-article...EN-MASTER-3-1-1.html
Release Notes:
The following user(s) said Thank You: mdm, EdgarZ
3 weeks 6 days ago
AMD released AMD Ryzen™ Master  3.1.2.5621  on November 2, 2026 for Ryzen 5000 and later
Release Highlights:
Fixed Issues:
  • N/A
Known Issues:
Release Highlights:
Fixed Issues:
  • N/A
Known Issues
Release Highlights:
Release Notes: www.amd.com/en/resources/support-article...EN-MASTER-3-1-2.html
Release Notes:
The following user(s) said Thank You: mdm, fikotr74
