AMD Ryzen Master Overclocking Utility v2.1x.x.xxxx
6 months 1 week ago
Release Highlights:
Release Highlights:
Release Notes: www.amd.com/en/resources/support-article...TER-2-14-2-3341.html
Release Highlights:
- Adds support for 105W Eco Mode to systems utilizing AMD Ryzen™ 9000 Series 65W and 120W desktop processors
- Adds support for systems utilizing AMD Ryzen™ 9000 Series desktop processors for the AM5 platform
- Adds an upgraded stress test (activated through the features 'Apply & Test' or 'Curve Optimizer Automatic')
- Memory can be overclocked on-the-fly (applying EXPO profile does not require a system restart)
- Additional memory tuning parameters are introduced, providing further customization options for optimizing memory performance
- DF P-state information is provided in the Home view
- In IRM control mode, users can now adjust the PBO parameters (EDC, TDC, and PPT) up to the IRM limits
- In Manual control mode, CPU speed can be adjusted in steps of 5 MHz
- An advertisement banner has been incorporated, providing information on AMD products
- This build now has support for 800 series AMD Socket AM5 Chipsets
- Support discontinued for AMD Ryzen™ and AMD Ryzen™ Threadripper™ 1000 and 2000 series processors
- N/A
- On some CPUs, stress test (activated through the features 'Apply & Test' or 'Curve Optimizer Automatic') might not fully stress the CPU or might require additional time to apply maximum stress. In such situations, consider increasing the stress test duration from the settings page
- There may be minor discrepancies between the duration specified by the user and the actual time required for the stress test to complete
Release Highlights:
- This update resolves the issue of certain CPU parameters being shown incorrectly after upgrading the BIOS on AM5 platform systems utilizing AMD Ryzen™ 8000G Series desktop processors
Time to create page: 0.072 seconds
