  • sdefrwggerg
  • sdefrwggerg's Avatar
2 years 10 months ago
Ask the manufacturer there's just no firmware for it and that's why you won't get any further.And this her is about RTL9210.
  • symbios24
  • symbios24's Avatar
  • User
  • User
there is nowhere to ask about it, i search in the manufacturer and nothing.anyway thanks
  • sdefrwggerg
then all you have left to do is buy a new with RTL9210 chipset. Unfortunately, that's all you can do.
forums.raspberrypi.com/viewtopic.php?t=362991
  • anonHZQT
  • anonHZQT's Avatar
Hello
I just bought the asus tuf gaming a1, and I heard all that use realtek 9210b chipset should update it firmware, I search online and the tools seem to be from here.
I don't want to broke my tuf a1 so here I ask, how to update fw without breaking it. I read that if there is problem with the update, with dump info then I would know what the original parameter are, but how to revert the update with that dump info I save before perform an update?
If any one here can provide me step about what to do and answer me how to prevent it from brick that would be a lot of help (I read here there a bridge 1 and 8 pin to reset? but I'm not confidence enough to do that)
here is my dump info
Device : [Port2] : TUF ESD-T1A #0
VID : 0x0b05
PID : 0x1a8a
MANUFACTURE : "ASUSTek"
PRODUCT : "TUF Gaming A1"
SERIAL : "NBD0AP055936"
SCSI_PRODUCT : "ESD-T1A         "
SCSI_VENDOR : "TUF     "
DISK_HOTPLUG : 0x00
PINMUX1 : 0x00000000
PINMUX2 : 0x00000000
DISK_IPS_THRES : n/a
CUSTOMIZED_LED : n/a
HW_LED_CFG : 0x80000081
FW Ver : 1.29.391
FW Build Date : 2022.07.28
IC Pkg Type : PCIE/SATA
the reason I want to update my tuf a1 is because the writing speed, reading speed is as what the spec was, but the writing speed is not.
Hi, you can update it without any problem, you just need to retrieve the configuration file to use it for the update
www.station-drivers.com/index.php/en/les...t-asus-tuf-gaming-a1
