  • spike_V_sky
  • spike_V_sky's Avatar
3 years 10 months ago
New firmware for RTL9210B - v1.30.21.070622 / RTL9210 A 1.29.8
Hi, are there any feedback about this firmware(1.30.21.070622) ?
on my side it works very well after I use it very little
  • sdefrwggerg
  • sdefrwggerg's Avatar
What is the difference between UTNVME and UTGDFW? I see GD being referred to as "Firmware Golden" but I don't know what that means.
This Firmware has three parts Config, UTNVME and UTGDFW. Use UTNVME as Firmware BIN and UTGDFW as Firmware GD. These two are paired with each other, flash always both.
@killman
You can try 1 and 7 but i think you have a Hardware Problem
Reset Pin Active low or to pause the device without deselecting the device
Serial data input and output for 4 x I/O read mode
[url] www.puyasemi.com/uploadfiles/2022/09/20220908185703573.pdf [/url]
  • Crillas
  • Crillas's Avatar
3 years 9 months ago - 3 years 9 months ago
Hi, I checked the firmware on my case and it is newer than the one you recently posted.
Fw version: 1.30.28 and build date: 2022.08.10.
I would like to make a backup and post it here, but I don't know how. Could someone explain to me what software is needed to make a backup? The mptool lite can only update the firmware, if I remember correctly.
Last edit: 3 years 9 months ago by Crillas.
Hello Crills ,
Yes shame but if the MPTool does not allow it, if someone else has the solution, I take
