Poll: What do you think of the new firmware?
Good
2 66.7%
Bad
1 33.3%
Total number of voters: 3 ( szyrzyk, steve3d, admin )
Only registered users can participate to this poll
  • steve3d
  • steve3d's Avatar
1 year 6 months ago
Thank you, after flashing this firmware, seems internal fan still not working.
1 year 6 months ago
Hi, you need to restore the original configuration file otherwise it may not work.
1 year 6 months ago
try replacing the configuration file below with the one from the latest package and reflash it
Last edit: 1 year 5 months ago by admin.
The following user(s) said Thank You: D-One
  • D-One
  • D-One's Avatar
I also have the Ugreen CM642, after updating it seems to run a little hotter... It has the same temps (according to MacOS) as my fanless ACASIS enclosure. I think something might be wrong with ugreens INI because even with their provided update tool this happens.
Anyway... I tried updating to version 2504417_85_00_00 but MPTool complained the ini file provided by Ugreen (as_mp_Toolv0.6.ini) is not compatible, its version=1008 instead of version=1009
Comparing the ugreen file with the one here from the latest firmware theres only 4 fields different:
version=1009
Reload_Waiting=5
CmdLineNoDevRetryMax=5
CmdLineNoDevDelayms=3000
Version is the first field and the rest is at the bottom of [usb_func], those 3 fields do not exist in the original ugreen INI so i added them, after those changes MPTool accepted the file and update seems to have worked. Other than being hotter everything is fine.
