- Julia
6 months 5 days ago - 6 months 5 days ago
@Shonk,
Set:
I have set everything apart from Idle Time (the setting in the ini is ignored for some reason)
Set:
[usb_config]
standby_timer=3
Last edit: 6 months 5 days ago by Julia.
the setting in the ini is ignored for some reason and it never goes to sleep
i use the pulldown to change it to 10 mins
and now power management works for me
the flash tool is slightly newer than when i tested this
so maybe its fixed in the tool i havnt checked
but i do it anyway to ensure power management works
Last edit: 6 months 5 days ago by Shonk.
6 months 4 days ago - 6 months 4 days ago
My antivirus blocked the MPTool and since then, despite my research, it has been impossible to remove the ban.
Last edit: 6 months 4 days ago by admin.
Last edit: 6 months 4 days ago by Shonk.
- H3li03
5 months 1 week ago
Hi there, I have a sandisk extreme enclosure with the same chipset, I was hoping to be able to flash a generic firmware to be able to use any nvme drive with it, cause with it's firmware, the device only recognize sandisk drive included...
I tried opening the flasher, but it seems it can't find the device from usb list, I was able to dump the firmware with asm firmware reader, the file name is asm_fw_181206_81_E3_08.bin
any idea?
thank, and sorry if it's a dumb request.
any idea?
