- simba
5 months 2 weeks ago
My hdd enclosure(RTL9201R) is on firmware 1.32.7 and is working correctly only on windows (usb 3 10Gbps speed) but would not show up on either mac (m2 pro), ios , android or linux, not even the usb is recognised. It uses external power adapter to power 3.5 inch drives. The drive works perfectly on mac os and other unix/linux when i use a usb 2 dongle albeit at usb 2 speeds. I have tried changing config settings but no luck. Does this chip not work with unix/linux or is this another problem on my enclosure
5 months 5 days ago
I had two UTHAI/ShuoLe U25N-L Enclosures arrive today they came with 1.34.29 Firmware
I have taken an SPI dump and edited it for Drive ID passthrough and such
It has 5 RGB LED's and does a nice rainbow effect
Here's its stock info
Device : [Port1] : RTL9201R #0
PID : 0x9201
MANUFACTURE : " "
PRODUCT : "RTL9201R"
SERIAL : "012345678985"
SCSI_PRODUCT : "RTL9201R "
SCSI_VENDOR : " "
DISK_HOTPLUG : n/a
LED : 0x03
PINMUX1 : n/a
PINMUX2 : n/a
U2_MAXPWR : n/a
U3_MAXPWR : n/a
ASPMDIS : n/a
DISK_IPS_THRES : n/a
CUSTOMIZED_LED : 41 02 00 00 00 00 00 00 00 00 00 00 00 00 00
SUSPEND_LED_OFF : 0x07
UART_DBG_PIN : 0x64
RW_MODE : n/a
FORCE_SATA_QUIRK : n/a
FW Ver : 1.34.29
FW Build Date : 2025.01.13
IC Pkg Type : SATA
- jelb0
5 months 4 days agoJeyi still hasn't come back to me about the issue. I suspect SUSPEND_DISK_OFF at 0x1 is the culprit. I won't do anything though, because I don't have the 9.34.11 firmware. If only I could download it from www.mydigit.cn/thread-564463-1-1.html .I know the problem your talking about
only a ch341a
- jelb0
4 months 4 weeks ago
They've sent me the firmware! It's still 9.34.11 but their .cfg fixes the disconnect after 1 minute issue.
wetransfer.com/downloads/5f7da54f1b393e5...0260701060827/e1c0d0
Something to pay attention to: Serial Number Settings > Increment Serial is enabled by default. I like to disable it.
VID = 0xbda
PID = 0x9201
MANUFACTURE = "Realtek"
SCSI_VENDOR = "Realtek"
PRODUCT = "RTL9201"
SCSI_PRODUCT = "RTL9201"
SERIAL = "012345678924"
DISK_IPS_THRES = 0
CUSTOMIZED_LED = 35 01 02
;DISK_HOTPLUG = 0x3
SUSPEND_DISK_OFF = 0x1
The following user(s) said Thank You: Shonk, Stasiz
- Stasiz
- poster 5
Excellent firmware. PERIPH_API for LCD is now supported. I successfully flashed the ShuoLe enclosure with BW LCD.
