1 year 3 months ago - 1 year 2 months ago
The Price isnt that good its £21.82 delivered for a cheap looking enclosure
look at that pcb it looks like i made it at pcbway
I picked up an Integral 256GB USB3.2 Type-C Ultima Pro X 2 a few months ago for £25
Which is a Turnkey Phison PU31-Pro made directly by phison
that oem's then buy and badge
It comes with two Very High Quality Cables and a Case
Its an ASM2364 with a Phison E13 with 256GB of Toshiba 96L TLC
I pulled the drive and replaced it with a 1TB Kioxia Exceria G2 that i picked up for £29.99
I have one of these coming from aliexpress for messing with
to see if i can clone every setting on my PU31 Pro Firmware
it was like £10 delivered
It has an asm2364 im hopeing for a newer firmware on it that i can dump for my Phison PU31 Pro
Will post it here if its newer
It should be here in 3 days
1 year 2 months ago - 11 months 2 weeks ago
Here are two firmware's dumped from my devices
AS_PCIE_200505_90_00_00.bin (My Phison PU31-Pro) 05 May 2020
AS_PCIE_201012_91_00_00.bin (Silverstone MS12) 12 October 2020
AS_PCIE_210901_91_00_00.bin (My Samget Enclosure) 01 September 2021
Dumped with Asmedia_FW_Dumper_0.21a
130 bytes at start of file removed (My NvRam)
Padding at the end of the file removed
It was simple to clone the NVRAM
the first 4 bytes are hard coded to the hardware so they stay the same
00 40 10 FF on the Phison PU31-Pro
00 60 13 FF on the Samget
The rest was just
VID
PID
Serial Number
EP0 M.String
EP0 P.String
T10 M.String
T10 P.String
Idle Timer = Never on PU31-Pro & 10 Mins on Samget
nothing extra in the ini needed to be changed
I Removed the Customization Integral added and renamed it from
Integral PU31-Pro to Phison PU31-Pro (thats what Phison sets them as by default)
to match my Phison PU31 (JMS583) (That AXE didnt customize to AXE PU31)
With Silverstone MS12 Updater Config
mega.nz/file/0iRBRKBJ#AL-7Vm6fhHKmpSBdxz...cWXnx8YyFBMEpQ6G9qX0
With Phison PU31-Pro Updater Config
mega.nz/file/s3hS2TxA#kFNjJ0e3A12ASen13W...FA8h4UzzXldFh6xPCMrY
With Samget ASM2364 Updater Config
mega.nz/file/ljQHga4T#gjYkAvjqfk4Cla9oN1...MVT-m2s5WIYEkmEv2N-M
You can use either..
The rest was just
VID
PID
Serial Number
EP0 M.String
EP0 P.String
T10 M.String
T10 P.String
Last edit: 11 months 2 weeks ago by Shonk.
1 year 2 months ago
I tried uploading the firmware to the main site but it gives me error's i have reached my limit and such
can you upload it admin..
- Vurmiraaz
MPTool not recognizing my ASM2364 in an Orico 20Gbps Enclosure
I tried all different firmware update tools I can find - 19xxxx, 20xxxx and 21xxxx but none of them would show my ASM2364. Tried with and without drive, same problem.
Clicking Start button does nothing - the progress bar is stuck at 0%.
Anyone has the same problem? Please help me out because I need to update its firmware to at least 19xxxx to use it with flashid. Thanks!
Last edit: 1 year 1 month ago by Vurmiraaz.
