dial Problems S-D
  • Tom's Avatar
Re: Problems S-D
7 months 1 week ago
#3362
Ok, not really a problem, but since today the forum is "nestled" in between the side frames like on the homepage.
This makes it pretty hard to read because everything is now smaller.
 Not sure what others think about that.
Re: Problems S-D
7 months 1 week ago
#3363
Hi Tom, I did a test and put it back as before.Sorry
The following user(s) said Thank You: Tom
  • tistou77
  • tistou77's Avatar
Re: Problems S-D
7 months 1 week ago
#3364
Rien de changé de mon côté j'ai l'impression
Re: Problems S-D
7 months 1 week ago
#3365
Oui j'ai fait un test d'intégré les barres laterales mais cela fait trop petit.
Je laisse juste cell de gauche et dit moi si cela est genant Tom & Tistou
  • tistou77
  • tistou77's Avatar
Re: Problems S-D
7 months 1 week ago
#3366
C'est bon pour moi avec la barre des icones à gauche
