Problems S-D
Re: Problems S-D
4 months 3 weeks ago
Despite several versions the problem persists but it's strange that a section is affected, that of Intel I will see more this evening because I have to leave
Re: Problems S-D
I am not sure, but maybe there was a code update which is incompatible.between October 19 and 25.
Btw. now the front page doesn't show the latest updates to the forum on the left.
Re: Problems S-D
yes I will put the left menu back and do a test by copying from one section to another to see if it comes from the Intel graphics section
Re: Problems S-D
So I did a copy and paste from a previous topic and it works but strangely those posted recently are not editable, can you do a test again Tom to see if it works again
Re: Problems S-D
I am not sure it is related to that, but when I went to my Preferences and selected an Editor as default, I get the following error message: "Unknown column 'yim' in 'SET'" and "Error on saving profile".
I was hoping that I can select somewhere to switch to Source instead of HTML, but this option is not available.
Maybe the above error message has something to do with that problem.
I'll do some more tests.
Last edit: 4 months 3 weeks ago by Tom.
