  • Tom's Avatar Topic Author
2 years 2 months ago - 1 year 11 months ago
#911
AMD released v2.10.3.2419 on April 25, 2023
Release Highlights:
  • Memory overclocking support for AMD A620 chipset based motherboards.
Fixed Issues:
  • Issue related to CPU Voltage range is fixed. Users can now apply voltages beyond 1.52V.
Known Issues:
  • Not all features are visible or supported on Legacy Processors.
Release Notes: www.amd.com/en/support/kb/release-notes/...n-master-2-10-3-2419
Last edit: 1 year 11 months ago by Tom.
Re: AMD Ryzen Master Overclocking Utility v2.10.x.xxxx
2 years 3 weeks ago - 2 years 2 weeks ago
#1185
AMD released v2.10.3.25042514 on June 515, 2023
Release Highlights:
  • On systems with AMD Ryzen™ 7000 series processors, the Ryzen Master menu setting for SoC voltage input is limited to 1.3V when not in LN2 mode.
Fixed Issues:
  • Issue related to CPU Voltage range is fixed. Users can now apply voltages beyond 1.52V..
Known Issues:
Release Notes: www.amd.com/en/support/kb/release-notes/...n-master-2-10-3-2504
Last edit: 2 years 2 weeks ago by Tom. Reason: Update to v2.10.3.2514. Links stay the same
#1364
AMD released v2.11.1.2623 on July 26, 2023
Release Highlights:
  • Security updates included in this release.
Fixed Issues:
  • None
Known Issues:
Release Notes: www.amd.com/en/support/kb/release-notes/...n-master-2-11-1-2623
1 year 10 months ago
#1466
AMD released v2.11.1.2659 on August 9, 2023
Release Highlights:
Fixed Issues:
  • None
Known Issues:
Release Notes: www.amd.com/en/support/kb/release-notes/...n-master-2-11-2-2659
  • porkdelicious
  • porkdelicious's Avatar
1 year 7 months ago
#1986
scratch geometry dash
Release Highlights:
Fixed Issues:
Known Issues:
Users can customize everything from individual cores to memory voltages and pretty much everything in between using the software.
